Forums >> Revit Building >> Technical Support >> Revit 2011 - show ceiling-hosted objects on floor plan?
Tue, May 3, 2011 at 4:12:14 PM | Revit 2011 - show ceiling-hosted objects on floor plan?
smetz
I'm trying to show ceiling hosted exit signs on my code analysis floor plan, but I can't figure out how to make them show up outside the RCP.  Thoughts?
Thanks for your help!
Stephanie
Tue, May 3, 2011 at 4:47:23 PM | Revit 2011 - show ceiling-hosted objects on floor plan?
pchan
pchan Avatar
5 Stars: 5 Votes
Have you tried using overlay under view properties of the level?
Go to the view properties there should be a field called underlay, choose the RCP level you desire and OK
Tue, May 3, 2011 at 5:16:56 PM | Revit 2011 - show ceiling-hosted objects on floor plan?
smetz
Thanks, pchan.  I did try that, but it doesn't give me the RCP as an option for the underlay.  I read in another thread that drawing an invisible model line from the fixture to the floor in the family editor works.  I tried that, and it sortof worked, but instead of the symbol for the exit sign showing up, it's the perimeter of the fixture model...still working on it.
Tue, May 3, 2011 at 5:23:42 PM | Revit 2011 - show ceiling-hosted objects on floor plan?
pchan
pchan Avatar
5 Stars: 5 Votes
there should be another field just below "underlay" that said underlay orientation and choose RCP there!
don't use the model line trick on the exit sign family since that will cause all the family show up on the plan view where this is an RCP object.
Tue, May 3, 2011 at 5:47:48 PM | Revit 2011 - show ceiling-hosted objects on floor plan?
smetz
wow -thanks for the underlay orientation tip! I had never thought to look there!
So, it turns out it was just a matter of making object visible in fine detail mode.  I do want it to show up on the floor plan view - it's for a code analysis plan, for which I'm using the floor plan as the base.  I'll just turn them off in my regular floor plan.
Thanks again for your help!
Ceiling objects cut by walls
Fri, Nov 20, 2009 at 12:58:09 AM
Ceiling Mounted Receptacles
Mon, Mar 19, 2012 at 12:19:14 PM
Floor Plans need to show Ceiling on them in Revit 2011
Thu, Aug 26, 2010 at 12:40:35 PM
Ceiling Mounted Family Visibility in Floor Plan
Tue, Feb 3, 2009 at 7:48:39 PM
Need to get ceiling based mechanical hood to show up in floor plan
Wed, Jul 27, 2011 at 8:43:30 PM
Page generation time: 5.6309
