Forums >> Revit Building >> Technical Support >> Doors make a gray shadow in Sections
Tue, Apr 6, 2004 at 10:20:30 AM | Doors make a gray shadow in Sections
sjs
sjs Avatar
3.5 Stars: 10 Votes
Every time that a sections pass in front of a door, the section display a gray shadow. Enyone know how resolve this problem. Note: Gray shadow in shading mode. White shadow in Hiden mode. Tks.
Tue, Apr 6, 2004 at 12:18:34 PM | RE: Doors make a gray shadow in Sections
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
what do you mean by shadow? Is it on your wall or something?
Hiroshi Jacobs
Wed, Apr 7, 2004 at 5:55:21 AM | RE: Doors make a gray shadow in Sections
sjs
sjs Avatar
3.5 Stars: 10 Votes
I have send you an email with some pictures.
Wed, Apr 7, 2004 at 9:19:18 AM | RE: Doors make a gray shadow in Sections
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
I think it's because your section is cutting through your door families. I have noticed the same problem with cutting through other families. What happens is if you have symbolic lines, they are considered part of the family so even though it may not look like it, you're actually cutting through it. try moving your section away from the door so that it doesn't cut through the swing.
Hiroshi Jacobs
Wed, Apr 7, 2004 at 10:39:43 AM | RE: Doors make a gray shadow in Sections
sjs
sjs Avatar
3.5 Stars: 10 Votes
Yes, i know is because the section cut part of the family, even if is just symbolic lines. But sometimes i can't move the section line. Well, i see there is no way to remove this gray shadow off the sections. Meaby in a new release.... Tks any way. Smile
Gray walls
Tue, Jun 13, 2006 at 1:07:37 PM
Doors displaying as gray in Shading with Edges
Thu, Aug 6, 2009 at 3:46:42 PM
shadow projection on walls
Thu, Apr 14, 2011 at 2:29:41 AM
section view
Thu, Nov 8, 2007 at 12:28:15 PM
Shadow density / weight
Fri, Feb 6, 2015 at 12:47:56 PM
Page generation time: 3.0691
