Forums >> Community >> Newbies >> Stairs connecting properly...
Sun, May 1, 2011 at 11:19:11 AM | Stairs connecting properly...
jayman777
Hi, I'm having issues getting my stairs to connect properly between floors. I have the "start from" and "connect to" set on the correct levels of my model, but, they never reach the top. I've posted two pictures to show you what the basic settings are at, as well as what I'm hoping they will turn out like...
Any help you can offer would be great. This isn't the first time Revit has given me trouble with stairs connecting.
Thanks,
Jay
Sun, May 1, 2011 at 6:30:47 PM | Stairs connecting properly...
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Ensure the desired number of risers matches the actual number of risers drawn in your stair sketch.
Regards,
Chris.
Mon, May 2, 2011 at 3:55:39 PM | Stairs connecting properly...
DeifyMe
4 Stars: 2 Votes
I don't think you're providing enough room for the required number of treads. The stair family has max riser height which controls the number of treads required. Select your stair and hit "edit sketch", does it say 0 risers remaining?
Connecting Stairs to top level
Fri, Jan 20, 2012 at 2:20:09 PM
13
Revit stairs.. connecting supports.
Fri, Jul 6, 2012 at 8:20:23 AM
Fri, Jan 20, 2012 at 7:29:53 AM
stairs not connecting to landing- see attachment please!
Mon, Mar 5, 2012 at 12:29:45 PM
Surface pattern on stairs
Mon, Mar 29, 2010 at 6:47:25 AM
Page generation time: 0.5275
