Forums >> Revit Building >> Technical Support >> Mass object
Fri, Apr 29, 2011 at 3:52:01 AM | Mass object
nirim
5 Stars: 12 Votes
Hi there
I been created that element using the revolve method and then change the end angle from 360 to 36, how do I make it in to a solid element?
nirim
Fri, Apr 29, 2011 at 1:57:26 PM | Mass object
4 Stars: 205 Votes
Now select those 4 lines and click on "Create form" like you can see in my irst image, then you will need to create a couple of Voids to cut the exceeding form like you can in the third image.
This is the "Hard Way" to solve the problem, now look at the next post to see the "Easy way".
Edited on: Sat, Apr 30, 2011 at 6:46:49 AM
Sat, Apr 30, 2011 at 6:47:36 AM | Mass object
4 Stars: 205 Votes
And this is the "Easy way": http://screencast.com/t/X1QVY5ktN0sP
Tue, May 3, 2011 at 2:51:42 AM | Mass object
nirim
5 Stars: 12 Votes
Thank you Typhoon
Making an object from solid mass...
Mon, Oct 25, 2010 at 7:17:06 AM
hosting object to reference point in mass family editor
Fri, Apr 4, 2014 at 1:45:49 PM
How to change material properties of a mass
Tue, Nov 18, 2008 at 11:46:25 PM
Chaning mass objects
Fri, May 8, 2009 at 3:41:08 AM
Mass object not showing
Sun, Aug 10, 2008 at 12:07:28 AM
Page generation time: 1.7395
