Forums >> Community >> The Studio >> CONVERT RHINO TO REVIT
Thu, Apr 28, 2011 at 11:04:58 PM | CONVERT RHINO TO REVIT
peerage
4.5 Stars: 2 Votes
Hi I'm trying to convert my file from Rhino to Revit, I export as an .sti and get the following error
'Some ACIS objects could not be imported. To import them, use AutoCAD to convert them into polymesh objects and reimport.'
I have attached the file for convert... any ideas?
Fri, Apr 29, 2011 at 4:06:59 AM | CONVERT RHINO TO REVIT
4 Stars: 205 Votes
Look at the bottom of this page, you will see similar threads about this same issue, this question was answered several times....
Fri, Apr 29, 2011 at 11:25:32 AM | CONVERT RHINO TO REVIT
grid
.sat for nurbs .dwg for meshes. They both import well as masses.
Palm Springs Architect using Revit LT!
Tue, May 24, 2011 at 7:22:55 PM | CONVERT RHINO TO REVIT
peerage
4.5 Stars: 2 Votes
Because of a number of factors I have a building mass modelled in Rhino. I need this model to be a mass in Revit. (so I can mass the floors, façade systems and so on)
Exporting the model as a .dwg sort of works but I don’t know how to create the mass from the geometry that is imported into Revit. Make sense? Help!
(Online they seem to indicate that exporting the rhino file as a .sat which work too but … No success)
I’ll attach the files if you have a moment, to look at it, I need to know how to mass that exact shape, selecting the lines doesn’t really work either because of the undulation of the façade.
Tue, May 24, 2011 at 9:11:37 PM | CONVERT RHINO TO REVIT
vector23
vector23 Avatar
2 Stars: 16 Votes
you will never convert a DWG into something revit- ever..
DWG mixes with revit like oil mixes with water..
keep it out of your revit project.. like open it in another
session of revit and use it for reference only..
hold on- i have to go out for a few minutes but when
i get back i will create that thing in revit as a revit project..
and then you can ask me how i did it if you want..
PLEASE JUST  POST THE ORIGINAL DWG.. THAT
REVIT FILE IS CORRUPT..
Edited on: Tue, May 24, 2011 at 9:40:55 PM
Mon, May 30, 2011 at 10:05:13 AM | CONVERT RHINO TO REVIT
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
raaaaaawr >_<
There is a issue when you say , peerage, that you want to import rhino surfaces into revit, and is that it becomes dead geometry: you CANNOT modify that geometry once you import it, and as same happen to rhino, you have to rebuild the surface. OR you can learn the new mass environment, its a little less user friendly, and yes, you will spend some time trying to do the same thing you do in Rhino. But the good news is when you change something in that mass environment, you have to hit "update" on revit, and all will be faster and cleaner. Hope this helps.
Mon, May 30, 2011 at 12:31:59 PM | CONVERT RHINO TO REVIT
vector23
vector23 Avatar
2 Stars: 16 Votes
the most common revit question is about how to get (usually DWG)
sketches and linework into revit to become a revit project..
none of those files ever go directly into a revit project..
what you do is put them somewhere OUTSIDE of
your revit project and look at them and measure
them and printscreen parts of them and built the
thing in your revit project- from scratch.. you
can get very fast and efficient with that process..
if you know the program that created that sketch
or whatever linework it is- you can just refer to
it in that program and build it in your revit project..
otherwise import the DWG into a SEPARATE session
of revit as a "mass import" and you will be able
to slice it and dice it and do anything you need with
it so you can build it in your revit project..
Thu, Feb 13, 2020 at 5:10:11 AM | CONVERT RHINO TO REVIT
Sujannn
Hi there,
I just tried the BIMDeX product - Rhino to Revit Exporter for my recent final year project and it worked well. You might as well try this out and see whether it helps or not. Rather going for workarounds like going to AutoCAD and then Importing, you can just try the trial version of the BIMDeX product and see how it goes. I reached them at sales@bim-dex.com. I'd suggest you the same.
Thanks...
Editing revit file in rhino.
Thu, Feb 13, 2020 at 5:19:48 AM
Revit to Rhino
Thu, Feb 13, 2020 at 5:22:39 AM
URGENT HELP! Rhino polysurface to Revit Mass
Fri, Nov 20, 2015 at 11:27:53 PM
rhino
Mon, Aug 7, 2006 at 6:07:17 PM
Import Rhino model into Revit
Mon, Mar 3, 2014 at 7:42:36 AM
Page generation time: 1.6129
