Forums >> Revit Building >> Technical Support >> Bringing an SKP file into RAC 2011
Thu, Apr 28, 2011 at 9:09:57 AM | Bringing an SKP file into RAC 2011
MarkBryanDesign7
So I have read the posts in the forum and most say to start a massing family in the project or start a mass component family and import into a project. I have tried both, in 3D views, to import and everytim it says cannot import the skp file. Am I forced to export a dwg from sketchup to import?
Thu, Apr 28, 2011 at 10:10:27 AM | Bringing an SKP file into RAC 2011
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
No, be sure to click on "create mass" before you import the skp
Thu, Apr 28, 2011 at 10:14:35 AM | Bringing an SKP file into RAC 2011
Why not just learn to mass in Revit?  Then you can alterit when needed.
Thu, Apr 28, 2011 at 11:55:39 AM | Bringing an SKP file into RAC 2011
MarkBryanDesign7
In a new project, in the 3D view, I go to Massing&Site, In-Place Mass, name it, Insert, change to skp file type and select the file. I get an error message that says cannot open.
I am importing from a previous client, so trying not to duplicate the work.
Thu, Apr 28, 2011 at 4:43:37 PM | Bringing an SKP file into RAC 2011
pchan
pchan Avatar
5 Stars: 5 Votes
Did you try create a Mass family and do the import skp file into the family?
Thu, Apr 28, 2011 at 6:23:19 PM | Bringing an SKP file into RAC 2011
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Yep.  Start an in-place family, in the "mass" category.  Or is it generic model... anyway, import the .skp file.  Should work -- and you can possibly do a single partial explode.  You'll be aple to paint the faces on this model, but you'll find that otherwise it's impossible to alter.  You can also apply walls by face, for example.
You can use this technique to duplciate sites/neighboring buildings, if they've been modeled in detail early on for conceptual stuff, for example.
Fri, Apr 29, 2011 at 8:20:22 AM | Bringing an SKP file into RAC 2011
MarkBryanDesign7
Yes tried it both as a family and in a project. Neither worked.
Thu, Jul 4, 2013 at 7:33:38 AM | Bringing an SKP file into RAC 2011
NorskJ
Hi, Did you ever find a solution to this problem? Two years later, I am using Revit 2013 and sketchup 8 and I am having the same problem with no solution.
Mon, Jul 8, 2013 at 1:41:20 AM | Bringing an SKP file into RAC 2011
ronmalit
5 Stars: 3 Votes
hi,
i am using rac2012/13/14 and sku8 and theres no problem at all
we can try solving this 2 year old issue by attaching your skp file.
** dont be mad, i dont have much... i am homeless
Revit 2017 In Place Mass
Tue, Jul 12, 2016 at 3:06:48 PM
Import SketchUp
Sun, Feb 8, 2009 at 3:00:23 AM
Can't import SKP file!
Sun, Feb 8, 2009 at 3:58:59 PM
SKP to RVT
Sun, Apr 22, 2012 at 6:42:04 AM
Converting .skp files to .rfa?
Fri, Jun 25, 2010 at 3:05:23 AM
Page generation time: 2.4665
