Forums >> Revit Building >> Technical Support >> in-place coil spring
Wed, Apr 27, 2011 at 8:47:22 PM | in-place coil spring
vector23
vector23 Avatar
2 Stars: 16 Votes
how do i edit a path for a solid sweep
that starts on the first level work plane
and spirals up like a coil spring to higher
levels? something like spiral stairs..
or if i could get model lines that way
maybe i could pick that as a path?
there was once an answer here about "piecing"
together parts of the spring and building it up
or something- but i cannot imagine that..
revit 2011- thanks..
Edited on: Wed, Apr 27, 2011 at 8:54:00 PM
Wed, Apr 27, 2011 at 8:52:31 PM | in-place coil spring
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Swept blend.   I would draw a 180 degree arc for you path, and a rectangle for profile one and ground level, 2nd rectangle at X height. rotate and stack these as you please, and then use an outside edge of these objects as the picked 3D edge path of your more complex sweep.
That's just a first instinct idea, by no means the best idea I'm sure.
to expand on this:  It's probably better to do in two steps because it's difficult to account for the disortion of a swept blend between the two profiles.  A sweep is always perpendicular to the path however.  Swept blend profiles are vertical.
Edited on: Wed, Apr 27, 2011 at 9:17:14 PM
Wed, Apr 27, 2011 at 9:07:34 PM | in-place coil spring
itsmyalterego
4 Stars: 16 Votes
posted pic.  easy and fast.  Tip:  sometimes picking a path will give you an error.  Like stairs, shorten it, finish it, re-edit and make it more complex and the program won't complain.
edit:  sorry, images are refusing to upload.
Edited on: Wed, Apr 27, 2011 at 9:46:39 PM
Wed, Apr 27, 2011 at 10:45:48 PM | in-place coil spring
vector23
vector23 Avatar
2 Stars: 16 Votes
i sure did get this thing tangled up in
my mind before i figured it out..
i guess that's why it's taken me five
years to learn only half of revit.. oh well..
thanks alterego
Wed, Apr 27, 2011 at 11:21:07 PM | in-place coil spring
thetabest
thetabest Avatar
3 Stars: 2 Votes
this is when i wish i knew 3d max, a double helix is easy in it, so you could model in max then import to revit...
Trent Best
Best Systems
the.tabest@gmail.com
Wed, Apr 27, 2011 at 11:32:09 PM | in-place coil spring
vector23
vector23 Avatar
2 Stars: 16 Votes
no if you imported from 3ds max it would have to be
a DWG into a mass.. and the only thing you can
do with a DWG mass is use it for reference- preferably
in a separate session of revit.. none of these programs
can talk to each other.. 3ds and AutoCAD never even
heard of IFC.. sure you can send a revit model nicely
to 3ds if you really want to render with the same
rendering engine.. but you can't do anything with
a model from 3ds except look at it..
Wed, Apr 27, 2011 at 11:51:23 PM | in-place coil spring
thetabest
thetabest Avatar
3 Stars: 2 Votes
scratch another program off list of need to learns!  i was imagining the power of 3ds easily forming a mass  ..  tthought they touted this as a feature for 2012, ...?
Trent Best
Best Systems
Thu, Apr 28, 2011 at 2:16:41 AM | in-place coil spring
vector23
vector23 Avatar
2 Stars: 16 Votes
if you are an ARTIST- a DESIGNER- then ANY wireframe
modelling program YOU LIKE is the best one..
SketchUP- 3Ds Max- Bonzai3D- Maya- AutoCAD-
Revit massing etc. etc..
i'm not an artist/designer- i use revit for virtual
construction and documentation.. i PAY the artist
for their designs- and then i build them into something
real that i can sell.. i don't care if designs come from a
program that generates .dwg- .skp or from revit
massing- it's all the same to me..
maybe autodesk thought it would be convenient
for me if my designs came from revit massing-
so they built up what used to be a very very
simple massing program that was built into revit..
it used to be useful for things like form roofs
and some kinds of in-place families- i guess..
until a few weeks ago before autodesk
released this new stand-alone massing
part of revit- not many artists would buy
the whole 5000 dollar revit program
just for designing.. and artists who are also
builders are not common..
but i think autodesk made a smart move
turning revit massing into a full-blown
design program- because just look at
all the revit art work that's come into
the revit city gallery..
Thu, Apr 28, 2011 at 7:03:09 AM | in-place coil spring
Single and double Helix's have been produced in Revit for sometime.  Here is a quote from Everything Autodesk Revit & BIM  2009 on a competition HOK did:
“The most exciting moment of my design was when time was up, and I transferred all the Parameter information to a nested set of the simple elements. In the click of a button I asked Revit to recalculate over 4500 values, model 1600 solids, regenerate around 20 views, most shaded and shadow-enabled and including perspectives. It took around 3 tense minutes for a quite cryptic image on screen to become the bridge I had in mind.”
....now do that as easily in max
Edited on: Thu, Apr 28, 2011 at 7:04:32 AM
Thu, Apr 28, 2011 at 1:06:06 PM | in-place coil spring
vector23
vector23 Avatar
2 Stars: 16 Votes
that's a powerful revelation Hub-
if twisted-shape architecture takes off like
autodesk is betting it will- no program can
construct AND design it as well as revit..
so then what i used to think of revit massing
as just being for creating twisted roof extrusions
on rare occasions was really a key to the future
of commercial architecture?  probably better
leave bridges to AutoCAD though..
Sun, May 15, 2011 at 4:46:28 AM | in-place coil spring
McDave
vector 23 ->
".. and artists who are also
builders are not common.."
they're called architects :-)
Sun, May 15, 2011 at 4:01:20 PM | in-place coil spring
vector23
vector23 Avatar
2 Stars: 16 Votes
McDave- i'm very impressed with your intelligence and perception..
i agree with you.. i hope we can be partners..
Sun, May 15, 2011 at 4:24:05 PM | in-place coil spring
#13
vector23
vector23 Avatar
2 Stars: 16 Votes
McDave- the only thing is- there's nothing on the ARE to do with aesthetics..
Sun, May 15, 2011 at 4:51:04 PM | vector23
#14
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting vector23 from 2011-05-15 16:24:05
your are correct. The elevation requirement was removed serveral years ago.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
How to model a spring?
Wed, Jul 8, 2009 at 4:48:51 AM
Seeking an Internship for Spring 2009 semester
Tue, Nov 25, 2008 at 3:31:21 PM
Razor Wire
Fri, Jan 23, 2015 at 6:01:02 AM
Can't place some components without creating floors (REVIT Architecture 2013)
Fri, Dec 14, 2012 at 2:49:55 AM
in place massing problems
Thu, Jul 16, 2009 at 6:41:44 AM
Page generation time: 0.7778
