Forums >> Revit Building >> Technical Support >> Beams
Tue, Nov 15, 2005 at 12:39:34 PM | Beams
broncos4life
3.5 Stars: 11 Votes
I have Revit 8 on my laptop and I have seen that I can put beams and things like that in on it, but I am working on revit 7 at my work and I cant seem to find how to put beams accros my house under my roof. Is there anyway to do beams or something like 4x4 post running horizontaly?
Tue, Nov 15, 2005 at 2:48:32 PM | RE: Beams
Rythmick
5 Stars: 2 Votes
The top of beam will be on the working plane you place it on. You can adjust its offset parameter from there. The beam can be any family shape you assign it. For a 4x4 use a wood beam family and adjust the width & heigth parameters accordingly to create a new family type.
Tue, Nov 15, 2005 at 3:41:26 PM | RE: Beams
broncos4life
3.5 Stars: 11 Votes
Ok, but how do I even make a beam in Revit 7?
Tue, Nov 15, 2005 at 10:56:24 PM | RE:
Merlin
Quoting broncos4life - 2005-11-15 15:41:26
"Ok, but how do I even make a beam in Revit 7?"
You add a component, in this case, it'll be a dimensional lumber (one is in your library). It is a parametric family so you enter in the depth and width you want. BUT remember that you may want to first set your working plane to the roof surface!
After you've put it in, you can edit the end profile to suit the trim on the ends of your rafters by using the....sorry, I can't tell you offhand the name of the tool needed (I haven't got Revit on the computer I'm using currently)
HTH
John Mc
Wed, Nov 16, 2005 at 9:43:20 AM | RE:
Rythmick
5 Stars: 2 Votes
Go through the tutorials on using families and the family editor.
joining two beams
Fri, Jul 6, 2007 at 12:03:10 PM
making beams dotted and upstands
Tue, Jun 3, 2008 at 3:50:24 AM
Beams that are copied are invisible, while beams placed can be seen??
Sat, Jan 20, 2007 at 9:53:43 AM
RVT2015 - Insert steel beams over doorway
Tue, Apr 25, 2017 at 9:06:47 PM
Battered ends of L-Beams
Thu, May 9, 2013 at 12:32:50 PM
Page generation time: 0.1859
