Forums >> Revit Building >> Technical Support >> Drafting View 'Phase Parameter'
Tue, Apr 26, 2011 at 8:23:49 AM | Drafting View 'Phase Parameter'
nichitect
Does anyone have a way to add the parameter of 'Phase' to a Drafting view so that in the project browser it will group itself with the other views created in that phase.  For example, a detail created in the New Construction Phase should group with the other New Construction views and not under the '???'. We are using Revit 2011.
Thanks.
Edited on: Tue, Apr 26, 2011 at 8:24:31 AM
Tue, Apr 26, 2011 at 1:39:07 PM | Drafting View 'Phase Parameter'
Nothing automatic like you want.  You can add view parameters and sort your browser any way you want.
Flagging new Drafting Views - How to reference a drafting view detail?
Wed, Aug 1, 2007 at 10:26:29 AM
Revit2013 - 'Pipe Size' Parameter Can't Be Used
Mon, Jun 10, 2013 at 2:25:34 PM
Roof Phases
Mon, Jul 10, 2006 at 3:54:43 AM
Scaling Drafting Patterns
Fri, Sep 2, 2005 at 3:30:34 PM
Using standardized detail sheets
Mon, Apr 17, 2006 at 6:25:27 PM
Page generation time: 2.1708
