Forums >> Revit Building >> Technical Support >> wall hatch patterns not relative to wall direction
Tue, Nov 15, 2005 at 12:32:00 PM | wall hatch patterns not relative to wall direction
marshella1
Our firm is just starting revit, so this is probally a silly question, but here goes: We duplicated their standard ext. brick and block wall and want to make our cmu appear as lines (not their "x" pattern) that are always perpendicular to the wall lines. We saved and tried to draw our new wall and the horizontal (on the sheet) wall runs show the lines perpendicular, but the vertical walls show the lines vertcal, so there are 2 vertical lines representing the 7 5/8" cmu. Is there a way to make the lines relative to the wall direction? Thanks in advance.
Tue, Nov 15, 2005 at 5:19:49 PM | RE: wall hatch patterns not relative to wall direction
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Cut pattern lines cannot be rotated independantly, they are globally set in the fill pattern settings for that pattern and wall direction has no effect as you've discovered. Personally i believe this makes the most sense as if it was to alternate per wall direction there would be messy intersections where walls change direction and thus so does the pattern. Best bet is to set it to 45° or an angle that will be seen appropriate for the majority of wall directions... HTH.
WALL HATCH PATTERNS IN REFLECTED CEILNG PLANS 2009
Fri, Aug 29, 2008 at 10:01:31 AM
How to Import Hatch Patterns
Thu, May 31, 2012 at 1:16:12 PM
wall fill patterns for different wall types and phases
Sun, Apr 24, 2016 at 4:42:58 AM
Wall assembly hatch patterns
Mon, Dec 14, 2009 at 7:46:59 AM
Wall Hatch Switching Direction
Tue, Sep 8, 2015 at 6:31:27 PM
Page generation time: 3.8148
