Forums >> Revit Building >> Technical Support >> How to use different scale in the same drawing
Mon, Apr 25, 2011 at 4:45:26 AM | How to use different scale in the same drawing
Nadieliz
Hello,
Within the same drawing (the plan) I am required to have a blow up plan of just the bathroom. Now, my plan is at a 1/4" scale but they want the blow up of the bathroom at a 1/2" scale and I haven't been able to figure out  how to do that and put it in the same sheet without it changing my entire plan to half scale. Help? I am using Revit Arch 2011 student version
Mon, Apr 25, 2011 at 5:33:29 AM | How to use different scale in the same drawing
4 Stars: 205 Votes
Duplicate that view then you can have different scales for those views and you can insert them in same sheet
Mon, Apr 25, 2011 at 1:11:23 PM | How to use different scale in the same drawing
Nadieliz
Oh my God! Such an easy solution why didn't I think of it. Thank you!
Mon, Apr 25, 2011 at 1:30:46 PM | How to use different scale in the same drawing
Another solution is to use a plan call-out of the region you want to enlarge and you place that on your sheet.
Mon, Apr 25, 2011 at 9:52:23 PM | How to use different scale in the same drawing
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
a general advice... try to have an order with the naming of the duplicated views, as example
A101_PLANS
A101_A_ROOM_BATH
A101_A_ROOM_KITCHEN
The A after the A101 is for taking advantage of the alphabetic automatic order within revit... make your own order easiest possible to understand
Tue, Apr 26, 2011 at 2:06:37 PM | How to use different scale in the same drawing
grid
If it is just the bathroom you need to blow up I would do a call out region as suggested above. It will make referencing larger scale plan a bit easier once these are put on to sheets.
Palm Springs Architect using Revit LT!
drawing scale
Wed, May 18, 2005 at 11:26:04 PM
Tapping in to Current Drawing Scale for Use in Formulas
Wed, Oct 28, 2009 at 3:35:14 PM
I know how to scale patterns but to what
Wed, Jul 18, 2007 at 7:03:08 PM
How to dreate a new scale....
Sun, Mar 18, 2018 at 7:51:38 PM
Scale Issues in Titleblock
Thu, May 2, 2013 at 5:01:38 AM
Page generation time: 0.2405
