Forums >> Revit Building >> Technical Support >> How can we import rpc files into Revit Architecture 2011???
Sat, Apr 23, 2011 at 7:39:23 AM | How can we import rpc files into Revit Architecture 2011???
arxdomin
1 Stars: 1 Votes
Can you please help us?
Thank you
drdikefalos@gmail.com
Sat, Apr 23, 2011 at 8:12:26 AM | How can we import rpc files into Revit Architecture 2011???
4 Stars: 205 Votes
Home > Component > Place a component
Tue, Apr 26, 2011 at 2:41:42 PM | How can we import rpc files into Revit Architecture 2011???
baileyarc
Main Revit Options (Big R button, top left), choose options > Rendering tab > green plus symbol > click to the right of the blank rectangle it generates and it allows you to specify a path for your RPC Content.  You may have to close out of Revit once you add the path for it to show up in your image bank (Render Appearance Library) to choose your newly added content.
Fri, Apr 13, 2012 at 4:30:13 PM | How can we import rpc files into Revit Architecture 2011???
infinitywaves
infinitywaves Avatar
update for Revit 2012 and later - load RPC: insert/load familly/ (Your library / file) more info:http://help.archvision.com/products/autodesk-revit-architecture/getting-started-1/
I Can't use RPC content in Revit Architecture 2011
Fri, Jun 4, 2010 at 9:46:20 AM
HOW TO IMPORT 3DS files and DXF files into REVIT 2011?
Sun, Nov 7, 2010 at 6:21:00 PM
rpc file 2011
Sat, Jul 10, 2010 at 1:38:21 PM
Using 3D Studio Objects in Revit Architecture 2011
Tue, Sep 20, 2011 at 12:09:53 AM
Importing RPC Items - HOW?
Thu, May 12, 2011 at 6:41:13 PM
Page generation time: 1.4898
