Forums >> Revit Building >> Technical Support >> trimming mass floors revit 2011
Fri, Apr 22, 2011 at 11:12:36 PM | trimming mass floors revit 2011
rwh111
hi there,
i am having some problems with this. i have made a mass, generated mass floors, turned them into actual floors, and now i want to trim some edges of them to modify their boundaries. this works fine when dealing with straight edges of the floor boundary, but i cant use the trim tool with the curved edges. it wont even select them when i try to trim.
any suggestions?
thankyou.
Sat, Apr 23, 2011 at 5:53:00 AM | trimming mass floors revit 2011
4 Stars: 205 Votes
"this works fine when dealing with straight edges of the floor boundary, but i cant use the trim tool with the curved edges. it wont even select them when i try to trim" - like what? you always can "Edit Profile" of those floors and change the shape like you want, or, you can change the "MASS", load into project, select those floors and select "Update to face"
Autocad 2011 Solid To Revit 2011 Mass floor error
Mon, Feb 28, 2011 at 7:20:10 AM
extruded generic model and mass floors (2012)
Fri, Sep 21, 2018 at 3:36:03 AM
Mass Floors not all showing up - some missing
Wed, Apr 11, 2012 at 4:44:46 AM
Mass Floors with a Minimum Height/Clearance
Wed, Apr 18, 2012 at 5:25:50 AM
Multicategory schedule for mass and mass floors
Mon, May 4, 2020 at 5:45:48 AM
Page generation time: 2.5340
