Forums >> Revit Building >> Technical Support >> Opposing swing on doors
Tue, Nov 15, 2005 at 10:57:05 AM | Opposing swing on doors
Nathan
4.5 Stars: 3 Votes
how do you change the swing on a set of doors
Tue, Nov 15, 2005 at 5:22:50 PM | RE: Opposing swing on doors
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
They need to have a parameter built into the doors to begin with (usually an instance parameter). Once they have this you can then change all of a particular type by selecting one typing AI (Select All Instances also accessible from your right click menu) and then changing the instance properties of the door angle as required. HTH.
Wed, Nov 16, 2005 at 4:26:14 AM | RE: Opposing swing on doors
Nathan
4.5 Stars: 3 Votes
I dont think my message was very clear sorry. I am not trying to set the angle of the swing I am trying to get a set of double doors to swing both ways. Cheers
Wed, Nov 16, 2005 at 5:06:47 AM | RE: Opposing swing on doors
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Just add symbolic lines on both sides of the wall to show the swing going both ways in the family. If its already got swing lines in one direction, simply mirror them over the midpoint of the wall.
Fri, Aug 24, 2007 at 11:42:24 AM | Opposing swing on doors
MazterMind3212333
3.5 Stars: 7 Votes
What if I want the other swing's lines to be broken instead of solid?
Fri, Aug 24, 2007 at 11:51:50 AM | Opposing swing on doors
justinblack
Can you use the linework tool to change the linetype?
Sorry to jump in on you Mr.Spot!  I think the question was actually directed to you.
JB
Fri, Aug 24, 2007 at 12:03:49 PM | Opposing swing on doors
MazterMind3212333
3.5 Stars: 7 Votes
Nope, I can't click that one. I opened the family, mirrored the other swing but could not click the linework button...
Fri, Aug 24, 2007 at 12:08:04 PM | Opposing swing on doors
justinblack
If i understand you correctly, you tried to use the linework tool while in the Family Editor.
Try placing the door in your project (not inthe family editor) where you want it and then use the linework tool.
HTH
JB
Fri, Aug 24, 2007 at 12:16:06 PM | Opposing swing on doors
MazterMind3212333
3.5 Stars: 7 Votes
Nice, worked out perfectly. Thanks, pal.
Changing swing in different views
Tue, Nov 22, 2005 at 5:06:49 PM
Is it possible to separate metal and glass doors swing color in floor plan?
Mon, Sep 25, 2017 at 5:34:13 AM
Doors-Swing projection doesnt match Panel in Floor plan
Wed, Dec 14, 2011 at 10:03:05 AM
swing lines on casework doors
Fri, Jul 20, 2018 at 10:53:48 AM
45 degree door swing for Double Doors
Wed, Apr 11, 2007 at 9:56:41 AM
Page generation time: 2.9524
