Forums >> Revit Structure >> Tips & Tricks >> Spot Elevation Forced Text
Wed, Apr 20, 2011 at 8:10:10 AM | Spot Elevation Forced Text
littleguru
I need to have a symbol similar to the spot elevation with the "target filled" symbol and leader.  However I want to be able to change the text and not report the actual elevation.  This is for a "VARIES" elevation tag that is used in multiple sections.
Thanks
Fri, Apr 22, 2011 at 1:04:00 PM | Spot Elevation Forced Text
So edit your tag to create a new one that accepts next....
border on a spot elevation tag
Fri, Jan 29, 2016 at 2:52:39 PM
Spot Elevation Text
Tue, Mar 8, 2011 at 7:45:39 PM
Spot Elevation Override
Tue, Mar 5, 2024 at 7:26:45 PM
Spot elevations text on angle
Thu, Oct 18, 2012 at 9:08:09 AM
Spot Elevation vs. Level elevation
Tue, Aug 19, 2025 at 1:06:15 AM
Page generation time: 0.4973
