Forums >> General Discussion >> Wishlist >> Zamboni
Mon, Apr 18, 2011 at 7:16:42 PM | Zamboni
5dunhams
I am in need of an ice resurfacer or Zamboni. Please help.
Mon, Apr 18, 2011 at 8:44:54 PM | Zamboni
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
Here you have.
Now, the problemis transform this into revit, for that seek on the forum "sketchup to revit"
You should take a while ( 1 or 2 hours) to select and transform (change the color)  in autocad . Gl if you are in a rush.
Mon, Apr 18, 2011 at 9:54:49 PM | Zamboni
5dunhams
Thanks it's perfect
Tue, Apr 19, 2011 at 2:55:41 PM | Zamboni
5dunhams
Im having trouble converting it into Revit. Ive looked at some of the other threads and they dont give clear enough steps. Im new to Revit so I more straightforward steps. Thanks in advance.
Tue, Apr 19, 2011 at 6:27:31 PM | Zamboni
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
._. here you have, my young padawan. Now go and try to make a simple test proyect in sketchup, import it as is shown in the video, and after that try the zamboni ... it will take some time to change the color in autocad, so try to change it in sketchup earlier.
You have to make the same thing, but instead of importing the dwg file it into a "mass" you have to import it in a "generic model" (as example, you have to set it to a category later).
Tue, Apr 19, 2011 at 10:48:10 PM | Zamboni
5dunhams
This would work except that it requires sketchup pro
Mon, Apr 25, 2011 at 12:05:01 AM | Zamboni
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
go, seek on google for that... lazy lazy padawan ...
Tue, Apr 26, 2011 at 12:02:12 AM | Zamboni
5dunhams
Nevermind I just needed to import it as a mass into revit.
Fri, Mar 2, 2012 at 8:12:55 PM | Zamboni
5dunhams
Im looking for another Azmboni, except this one is an older model like the ones with the chian on the top
Zamboni
Fri, Feb 1, 2013 at 1:25:06 PM
Page generation time: 0.6552
