Forums >> Revit Structure >> Technical Support >> how can i make a rammed earth wall
Sat, Apr 16, 2011 at 8:15:55 PM | how can i make a rammed earth wall
quevedo12
how can i make a rammed earth wall on revit an use it on a every project file? can someone please help me with this problem?
Sat, Apr 16, 2011 at 9:16:51 PM | how can i make a rammed earth wall
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
check this (first link)and this , and your help (f1)
Sun, Apr 17, 2011 at 8:45:15 PM | how can i make a rammed earth wall
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
quevedo, speak spanish?
If the answer is yes... please join us in revitcity chat, from 10am to 6pm
Thu, Dec 6, 2012 at 1:31:56 AM | how can i make a rammed earth wall
rnorrish
Hi I was searching for the answer to this but ended up making one.
I used planting sand as the image with a travertine tile unlocked and re sized to create the bump. works really well
for graphics i found a drafting hatch made to suit and aligned with element seemed to work best.
Cheers all
Thu, May 4, 2017 at 9:34:49 AM | how can i make a rammed earth wall
andresvimos
rnorrish What about the thermal properties of the rammed earth wall? does anyone have a wall family of rammed earth that can share?
A la espera de sus comentarios.
Mon, May 8, 2017 at 11:37:12 PM | how can i make a rammed earth wall
rnorrish
here is the SRE wall i use. it is sand based so the physical properites have'nt been filled in but easy to do with some reasearch about your local SRE properties. They vary depending on soil type used. This is a useful link. In Australia the formas are 600mm high x 2400 long
http://www.ibpsa.org/proceedings/BS2009/BS09_1530_1537.pdf
Fillet to wall
Sat, Apr 16, 2011 at 9:14:46 PM
Earth and Wall cut patterns not showing in wall section...
Thu, Jan 5, 2012 at 3:08:36 PM
Below grade earth pattern missing
Thu, Nov 10, 2016 at 2:58:11 AM
Show earth hatch in sections, but not in elevations?
Thu, Oct 29, 2015 at 7:45:45 PM
Earth and foundations in Architectural Elevations
Wed, Feb 24, 2010 at 11:04:44 AM
Page generation time: 0.7792
