29 Users Online (27 Members):
Forums >> Revit Building >> Technical Support >> COST ESTIMATING WITH REVIT
1 Posts No Rating |
Has anyone figured a way to do cost estimating with REvit
5 Posts No Rating |
I've used it for residential purposes with the scehduling. REVIT will allow you to write equations and those are expressed as columns in the schedules. I've written schedules for walls, floors, ceilings, etc., that when I schedule the wall I can derive costs from the information already defined or associated with the wall. The great thing is REVIT will export a schedule to Excel which you can then customize to your hearts content the information you want to derive from the data inported from REVIT.
admin
Check out US Cost Success Design Exchange - it's a software that uses assembly codes from the Revit model & the US cost database to generate cost estimates from the bim model. http://www.uscost.com/designexchange.asp
Hiroshi Jacobs
The Catholic University of America |
check out this recently posted thread, it may be of help http://www.revitcity.com/forums.php?action=viewthread&thread_id=6102 HTH
2 Posts No Rating |
In our company we use CostOS Estimating it has an embedded visualizer where you can select entities and directly estimate what you see using commercial databases check it out: http://www.nomitech.eu/cms/en/c/bimestimating.html
Revit & Cost Estimating |
Mon, Jul 12, 2010 at 9:42:33 AM
Cost Estimating Software for Revit 2010 |
Fri, Jul 16, 2010 at 9:54:04 AM
cost estimating programs with Revit |
Tue, Oct 11, 2011 at 9:10:16 PM
Exporting Revit to Master Builder Estimating Software |
Wed, May 21, 2008 at 8:19:42 AM
Exporting model's information to a spreadsheet like MS Excel for cost estimating |
Wed, Nov 4, 2009 at 10:38:53 PM
