Forums >> Revit Building >> Technical Support >> how to change defined ref planes in a family
Fri, Apr 15, 2011 at 5:04:28 AM | how to change defined ref planes in a family
fairywiner
look, my sweep family,  the vertical ref plane has been defined as wall face, so when I upload this sweep to project file, the left of the sweep will attach to the wall, but actully I want to the horizontal ref plane to be defined as wall face. how to change it, also I  need to know how to difine exterior and interior for the ref plane. plus this sweeps was modified from a alreay made sweep by me, so the fucntion of ref planes has already been set.
 thanks!
沧海月明珠有泪
Fri, Apr 15, 2011 at 7:02:38 AM | how to change defined ref planes in a family
This does not look like a wall or face based family and as such, the reference plane name doesn't mean anything.  Just turn off "always vertical" in the family's settings and rotate it in the project.
If I am wrong and this is a face based or wall based object, then you will have to modify it in the family.
Sun, Apr 17, 2011 at 9:33:31 PM | how to change defined ref planes in a family
fairywiner
sorry, I didn't find the    Just turn off "always vertical" in the family's settings  as you said
also I have attached my frofile family.
Edited on: Sun, Apr 17, 2011 at 9:38:12 PM
Edited on: Sun, Apr 17, 2011 at 9:38:45 PM
沧海月明珠有泪
Sun, Apr 17, 2011 at 9:39:11 PM | how to change defined ref planes in a family
fairywiner
沧海月明珠有泪
Mon, Apr 18, 2011 at 2:07:00 AM | how to change defined ref planes in a family
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
Its simple as ... rotating the profile 90 º, reasign dimensions and reload.
Nested Family won't lock to 2 ref planes/lines
Fri, Jan 17, 2014 at 10:09:19 AM
Wish List - Toggle Reference Planes
Fri, Sep 24, 2010 at 1:23:59 PM
Moving reference planes in a family
Mon, Dec 4, 2017 at 8:23:29 AM
Ref Plane - Can colors be changed?
Wed, Feb 27, 2013 at 8:43:03 AM
Add parameter label to unequal parameters
Wed, Jul 11, 2012 at 11:52:29 AM
Page generation time: 4.0075
