Forums >> Revit Systems >> Technical Support >> Split Circuit Receptical Circuiting with Branch Duplex Recepticals
Thu, Apr 14, 2011 at 1:42:23 PM | Split Circuit Receptical Circuiting with Branch Duplex Recepticals
RareNiceGuy
Hello,
I've been trying to create a Split Circuit Receptacle that can each circuit can be circuited with a regular duplex receptical. I've been able to create a Receptacle with 2 Electrical Connectors that do the job, but I'm unable to create a tag that displays both circuits of the Receptacle.
Thanks for any assistance!
Thu, Apr 14, 2011 at 1:58:23 PM | Split Circuit Receptical Circuiting with Branch Duplex Recepticals
If 1/2 the receptacle was a nested (shared) family hosted in the other half, they should both tag.
Tue, Mar 27, 2012 at 3:07:09 PM | Split Circuit Receptical Circuiting with Branch Duplex Recepticals
jwilson18
Another method for tagging a receptacle with two feeds from seperate sources is to tag the wire. If you are not showing wiring runs, you can run a very small peice of wire ( so small that it won't be seen in any plan sheets) and tag each wire individually.
Turn off automatic select when circuiting?
Tue, Jan 4, 2011 at 7:28:11 PM
Multi-wire homerun tag out of order
Fri, Dec 9, 2011 at 10:18:57 AM
Electrical Circuiting
Fri, Oct 19, 2012 at 6:23:41 PM
3 Pole Panels?
Wed, Apr 11, 2012 at 2:57:16 PM
How to Wire Multi-Circuit Receptacles Within 1 Conduit?
Mon, Mar 21, 2011 at 1:19:06 PM
Page generation time: 0.0589
