Forums >> Revit Building >> Technical Support >> Facade Help (Toyo Ito tree concept)
Wed, Apr 13, 2011 at 11:21:29 PM | Facade Help (Toyo Ito tree concept)
creativeg
Can someone tell me how to create a facade like this in revit I was going to do it in rhino but I know there is a  wau to so it in revit whether its editing your wall profile drawing this and then putting a curtain wall behind it?...Any other suggestions
Wed, Apr 13, 2011 at 11:34:28 PM | Facade Help (Toyo Ito tree concept)
creativeg
Thu, Apr 14, 2011 at 7:40:14 AM | Facade Help (Toyo Ito tree concept)
I would do it as an in-place family. If you want glass in the "void"areas, just add a glass solid rectangle as part of the family.
Edited on: Thu, Apr 14, 2011 at 7:47:56 AM
Thu, Apr 14, 2011 at 8:36:27 AM | Facade Help (Toyo Ito tree concept)
rkitect
rkitect Avatar
4 Stars: 29 Votes
If the goal is to be rendered, I would make a material map with cutouts. This will achieve exactly what you have shown in render but not in shaded views.
If you need the geometry to be like this, you may want to head over to buildz.blospot.com and learn a lil about adaptive components to try to make this process a bit faster than the in-place comopnent method.
Thu, Apr 14, 2011 at 10:12:19 AM | Facade Help (Toyo Ito tree concept)
pchan
pchan Avatar
5 Stars: 5 Votes
I agree with Carl to go with adaptive Component with conceptual mass method.
It will be a much more flexible way to deal with if you decided to change your design later.
But the catch is to understand how adaptive component works first so you will know how to make one for yourself.
HTH
Newbie question - what else (Toyo Ito)
Sat, Jan 16, 2010 at 5:55:18 AM
Best method to draw architectural facade - pdf attached
Wed, Jul 24, 2019 at 10:00:54 AM
Tree
Fri, Jul 16, 2010 at 4:19:25 AM
rpc tree
Tue, Mar 31, 2009 at 12:01:03 PM
tree render
Mon, Oct 13, 2008 at 2:12:37 PM
Page generation time: 0.8305
