11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> How can I change the font of the entire interface?
I'm trying to customize my Revit font on the interface. Is this possible?
I have not seen anything on this. You can change the size of temporary dimensions.
Yes, you can figure out which font it is using and then rename that font in your font directory to something like Backup.ttf and replace it with the font you want to use. So if Revit is using Calibri.ttf, and you want it to be something like HandFS.ttf, then rename Calibri.ttf to Calibri.ttf.bu and rename HandFS.ttf to Calibri.ttf.
I DO NOT RECOMMEND DOING THIS AS IT WILL JACK UP ALL OF YOUR SYSTEM FONTS... but asyou can see it is possible...
You fell victim to one of the classic blunders. The most famous is never get involved in a land war in asia, but only slightly less well known is this! Never go in against a Sicilian when death is on the line! |
Awsome! Thanks guys. I'll mess around with it and we'll see what happens. Have a great day.
Stop the yearly interface updates |
Fri, May 13, 2011 at 8:38:20 AM
How do you change the font size and style on sheet detail titles? |
Fri, Aug 24, 2007 at 8:24:56 AM
Changing Fonts Globally |
Fri, Dec 7, 2007 at 12:34:29 PM
Move entire model to a different level!??? [ 1 2 ] |
Wed, Sep 1, 2010 at 9:10:29 AM
18
View Title with multiple font sizes |
Thu, Aug 8, 2013 at 11:04:11 AM
