Forums >> Revit Building >> Technical Support >> Revit MEP - Distribution System
Wed, Apr 13, 2011 at 10:53:36 AM | Revit MEP - Distribution System
Busch1724
I think I'm being an idiot, but I have an electrical system created and can't assign the system to a breaker box that I'm trying to put into a log cabin.
I've created the system under manage>electrical settings>distribution system. However when I bring in the breaker box/distribution panel it won't let me assign  that system to the box. The drop down menu just says "none". What could be the issue?
Wed, Apr 13, 2011 at 3:04:35 PM | Revit MEP - Distribution System
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
http://www.youtube.com/results?search_query=revit+electrical+tutorial&aq=1, there are a number of electrical tutorials. You must first set up your basic electrical system, then you must create circuits and then you can assign circuits to panel. Go through the youtube tutorials and you will get the hang of it. It is not well documented in the software.
Thu, Apr 14, 2011 at 6:44:46 AM | Revit MEP - Distribution System
Busch1724
Thanks a bunch.
Filtering BY Distribution Systems
Fri, Jan 21, 2011 at 9:50:15 PM
Revit MEP 2011 crashes when circuiting electrical devices.
Thu, Jan 27, 2011 at 9:27:58 AM
Assigning Distribution Systems
Tue, Dec 4, 2007 at 2:26:56 PM
New To Revit but diving In. Any Advice for MEP coordination
Mon, Jun 28, 2010 at 6:08:23 PM
Distribution board issues
Wed, Apr 3, 2013 at 11:39:56 PM
Page generation time: 1.7399
