11 Users Online (9 Members):
Forums >> Community >> Newbies >> New to revit. and Loving it. Few questions though.
3 Posts No Rating |
Hi Hi
I'm new to revit arc and have a few quistions.
Here they come:
- Lets say i have a wall. But i want to put different sections of color on it (paint etc) How do i do this. Because when I assign a render texture it does it on both sides and the whole wall.
- Also where to I install or copy the .pat files I download for patterns etc.
- Ceiling how do I Install a bulk head curved type ceiling I cannot find a video or tutorial.
- When I curve my beams they curve to the side. How to I arch a beam to the top. Or am i using the wrong component.
I appreciate every feedback
Thank You
Welcome to Revit's World.
1. use the "Split Face" then use the "Paint" tool (use your HELP menu)
2. create a new folder if you want
3. You need to create a "Model In-Place" in the right category, in this case "Ceiling"
4. the same in number 3
3 Posts No Rating |
Thanx a lot.
I'm going to bother you with one more quistion but I know there's still plenty to come.
I feel stupid to ask this but i can't find a tutorial.
When I create a family how to I assign parameters and colours to it. Can you maybe suggest a tutorial site. Because i downloaded a lot of books etc but they only give training on building etc.
Thanx again.
"If you don't ask for directions you'll get lost"
Download the families guide from the AutoDESK site.
for #3, I would do walls instead of in place component. Set the base offset to the bottom elevation of the bulk head. The bulk heads are actaully going to be a wall like structure if done like typical construction. You can then use edit profile to cut the curve. Use a normal ceiling to close the gap at the bottom of the 2 walls (one for each side depending on how the bulk head is situated in the space.
You'll find that there are many different ways to do the same thing, it all depends on what you are trying to accomplish with the model and how much time you have to do it. This is just how I model my nulk heads
Please state Revit version being used in your questions [ 1 2 ] |
Thu, Dec 15, 2016 at 6:32:17 AM
22
Newb from Wales / residing in Canadia! |
Fri, Jan 21, 2011 at 3:44:01 PM
noob with questions and some experience |
Sun, Oct 4, 2009 at 5:21:38 AM
New to Revit - First impressions LOVING IT ... but .. |
Fri, Feb 26, 2010 at 1:13:34 AM
Semi-New to Revit |
Fri, Sep 5, 2008 at 11:22:46 AM
