Forums >> Revit Building >> Technical Support >> Lighting fixture problems
Sat, Apr 9, 2011 at 1:31:13 PM | Lighting fixture problems
ramus2
Hello everyone, I'm using revit architecture 2011. I have a problem with lighting fixtures that I put in my ceiling + wall. I have checked the options and everything is how it should be - wattage comments, electrical type etc. But everytime I try to run interior artificial lighting only they dont seem to be working. Though the lighting fixtures I use on the desk does work. Anyone can inlight me please, I would appreciate it!
Thanks in advace,
Ram
Fri, Apr 15, 2011 at 1:47:25 PM | Lighting fixture problems
DeifyMe
4 Stars: 2 Votes
check the location of the light source in the family. It may be behind solid geometry and can't shine through.
Tue, Jan 29, 2013 at 1:48:57 PM | Lighting fixture problems
nate6923
i am having a problem with my canned lighting in my ceiling, the light will shine through and show up on the floor but when i render the view looking up at the light i do not see any light coming from the light itself, how do i get the light bulb to show up in the light, i like the way the light looks on the ground, but it looks very funny when you look up at the light and you do not see any light coming out of the fixture, can anyone help??
Tue, Jan 29, 2013 at 1:55:36 PM | Lighting fixture problems
Your "light bulb" needs to have a glow property set.
Tue, Jan 29, 2013 at 1:58:09 PM | Lighting fixture problems
nate6923
where do i do that at
Tue, Jan 29, 2013 at 2:04:36 PM | Lighting fixture problems
Here
But it needs to be the material you assigned in your family.
Edited on: Tue, Jan 29, 2013 at 2:05:49 PM
Thu, Nov 14, 2013 at 10:13:03 AM | Lighting fixture problems
choona
choona Avatar
Hi
I have some problem with lighting fixture that i download from revit city and also autodesk seek. I started to render, but  I can see some of can ressesed light didn't have any light , i checked ti famiy editor , they are fine but they didn,t ,, any help?
another problem with lighting is about material when i rendered  my ceiling ,i saw some of my ligting fixture that   called "Visa light" seem they are gypsum!!no light , no material !!! i try to check the material but i couldn't find any material bottom for checking.!! help please ,
Revit2012
Thu, Nov 14, 2013 at 10:24:29 AM | Lighting fixture problems
Please read the similar threads on lighting as your questions have been covered many times before.  Also learn more about families.  Download the families guide from the autodesk site and read it.
Typical lighting problems are caused by:
  1. Recessed light doesn't cut the ceiling.
  2. No light in the light...in other words - just something to look at in the model.
  3. The light is behind a solid object - like a lens which is NOT transparent.
  4. In-correctly assigned materials.
  5. Lights not turned on in rendering.
Fri, Nov 15, 2013 at 5:09:02 AM | Lighting fixture problems
Palazzo
Maybe this helps:
try to set the intensity of the light to a really high value (1.000.000 lm)
Tue, Nov 26, 2013 at 2:59:37 PM | Lighting fixture problems
choona
choona Avatar
Thanks
I changed the recessed material and I could solve my problem with your companySmile
Edited on: Tue, Nov 26, 2013 at 3:01:55 PM
Edited on: Tue, Nov 26, 2013 at 3:02:13 PM
Mon, May 8, 2017 at 10:43:49 PM | Lighting fixture problems
Brooks081
Revit 2016. I guess I don't get it.  At all.  I've tried putting ceilings in and the light fixtures end up in the floor.  Place it in first floor ceiling plan, fixture is literally in the toilet.  It would be great if there was a tutorial on this site......  I'm a student trying to learn this stuff, so please, if you respond, don't use revit code.  Kindly spell it out.  I'm reading some of these threads and frankly, they are way over my head.   Thanks.
Tue, May 9, 2017 at 8:26:21 AM | Lighting fixture problems
My first question is: Are you using a Revit reflected ceiling plan created from the plan options or did you copy a floor plan and call it a ceiling plan? That is a common mistake of newbies.  Read this.
Tue, May 9, 2017 at 8:21:47 PM | Lighting fixture problems
#13
Brooks081
Been watching you tube videos on the subject.  Follow all the steps to making a ceiling in the ceiling plan and placing lights in the ceiling plan.  Lights end up in the floor.....  Don't get it.
Wed, May 10, 2017 at 9:52:09 AM | Lighting fixture problems
#14
Your process is wrong somehow but too many possibilities for us to guess.  You need to tell us more and add some screen shots if you expect any help.
Lighting Fixture
Tue, Jan 8, 2008 at 7:33:08 AM
lighting fixture basic?
Sun, Oct 16, 2011 at 8:00:31 AM
Removing constraints on lighting fixture families
Tue, Apr 7, 2009 at 3:57:35 PM
Tagging Lighting Fixture Symbols in RCP
Fri, Dec 18, 2009 at 1:03:01 PM
gym lighting fixture
Tue, Jul 22, 2008 at 2:20:59 PM
Page generation time: 0.2048
