Forums >> Revit Building >> Technical Support >> How to render dwg in Revit correctly ?
Thu, Apr 7, 2011 at 9:53:07 AM | How to render dwg in Revit correctly ?
shenlunglinnk
3 Stars: 2 Votes
Hi
I imported a window from ACAD to Revit, and then changed all the materials according to other Revit windows (Steel frame and transparent glass).
The ACAD window looked right as other Revit windows when I used "shade with edge" or "realistic" modes.
However when I rendered, the glass turned into black color.....
Do you know how to solve it?
Thank you very much.
Fri, Apr 8, 2011 at 8:35:22 AM | How to render dwg in Revit correctly ?
DeifyMe
4 Stars: 2 Votes
First you'll have to "edit family" and make sure the glazing has a material applied to it. I find that alot of them are just set to "By Category". Then in your main model (if you hit "load into project", any materials changes will not overwrite), find that material name and under the "Render Appearance" tab, make sure you have an appropriate glazing material. Try setting the "Visual Style" to realistic before applying a render.
Tue, Apr 12, 2011 at 9:20:48 AM | How to render dwg in Revit correctly ?
shenlunglinnk
3 Stars: 2 Votes
Hi Deifyme
Thank you for your reply.
I have done what you suggested....but the rendering of the glass was still black .....:-(
Adding materials to DWG models
Sat, Nov 7, 2009 at 7:04:20 PM
Render imported DWG file
Sun, Dec 5, 2010 at 8:16:16 AM
Dwg to RFA and Materials.
Sun, Feb 2, 2014 at 1:40:54 PM
Cant import .dwg file correctly.
Tue, Jun 25, 2013 at 7:24:07 AM
Render in cloud window not displaying correctly
Thu, Apr 21, 2016 at 1:53:14 PM
Page generation time: 3.3737
