Forums >> Revit Building >> Technical Support >> Curtain wall with Wood Slats
Fri, Apr 1, 2011 at 2:44:18 PM | Curtain wall with Wood Slats
brooklya
I have a  wall that I want to be  a curtain wall with horizontal wood slats in front that act as a permanent shading system.  Any ideas for the best way to model this in Revit 2011??
Sat, Apr 2, 2011 at 7:02:42 AM | Curtain wall with Wood Slats
4 Stars: 205 Votes
Do you have any pictures so we can see what you really need?
Wed, Apr 13, 2011 at 4:42:03 PM | Curtain wall with Wood Slats
brooklya
See attached.
Essentially the louvers float in front or are attached to the frame of the storefront/curtain wall system.  I am thinking making an in-place family for this might be my best bet?
Wed, Apr 13, 2011 at 4:47:38 PM | Curtain wall with Wood Slats
brooklya
Same louvers at another location - top slopes with roof and opening cut-out to see glazing behind.
Wed, Apr 13, 2011 at 5:00:28 PM | Curtain wall with Wood Slats
cbieser
1 Stars: 1 Votes
Not sure if there's a better way but I think you are correct to model an in-place family.
Wed, Apr 13, 2011 at 5:13:39 PM | Curtain wall with Wood Slats
pchan
pchan Avatar
5 Stars: 5 Votes
I think you still can create the louver via curtain wall system
use 2 types of curtain system (set one of them to have a flat profile) and set it in front of the glazing system
Wed, Apr 13, 2011 at 6:27:54 PM | Curtain wall with Wood Slats
4 Stars: 205 Votes
Well, I created this with a "generic model line base" family (blade) then you can just "Copy" or "Array" that family....
Wed, Apr 13, 2011 at 10:32:53 PM | Curtain wall with Wood Slats
pchan
pchan Avatar
5 Stars: 5 Votes
This is done by using 2 types of curtain wall system. No custom family needed nor no array family.
Pretty easy to set it up and place it. You can also do it as an angle by edit profile.
HTH
Wood Slats
Wed, May 10, 2006 at 1:59:17 PM
Solid Wood Door in Curtain Wall ?
Mon, Aug 31, 2009 at 4:38:07 PM
Rainscreen/wood/vertical...how to?
Tue, Mar 11, 2014 at 11:36:09 PM
Mullion behind Glass Question
Tue, Mar 3, 2015 at 2:59:15 PM
wood paneling to a wall
Thu, Apr 22, 2010 at 7:24:53 AM
Page generation time: 1.5645
