Forums >> Revit Building >> Technical Support >> how to make a special grid curtain system,
Fri, Apr 1, 2011 at 7:35:48 AM | how to make a special grid curtain system,
fairywiner
I want to make a curtain, but the angle is not righle angle, I want the cross mullions just paralleled with the out sides of the triangle on the horizontal face, also I want to align the vertical mullion on the vertical face align with the end of the horizontal mullions.how to make the curtain system? see my picture5,3.   thank you!
沧海月明珠有泪
Fri, Apr 1, 2011 at 7:37:57 AM | how to make a special grid curtain system,
fairywiner
沧海月明珠有泪
Fri, Apr 1, 2011 at 12:52:53 PM | how to make a special grid curtain system,
4 Stars: 205 Votes
Did you try with "Curtain System by face"?
Fri, Apr 1, 2011 at 10:25:06 PM | how to make a special grid curtain system,
fairywiner
the picture shows what I mean, I want both the mullions of  two sides  are paralleled with the outside of the triganle, not just one sides of the mullions,  and the two sides of the mullion do not deed to perpendicular to each other.  is there some way to make this? thank you.
Edited on: Fri, Apr 1, 2011 at 10:49:29 PM
沧海月明珠有泪
Sat, Apr 2, 2011 at 12:54:58 PM | how to make a special grid curtain system,
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
Make that with a curtain panel by pattern... find it on your library, play with it a litle.
Check also the zach kron blog
curved curtain system -diagonal grid system?
Wed, Feb 11, 2009 at 4:24:47 PM
Curtain Grid Problems [ 1 2 ]
Wed, Apr 10, 2013 at 5:57:45 AM
19
Regular grid on Curtain system by face
Mon, Sep 30, 2013 at 2:57:17 PM
trapezoidal shaped curtain system????
Fri, Apr 14, 2006 at 1:17:53 PM
Curtain system grid _Rhino to revit
Wed, Jul 3, 2013 at 8:11:53 AM
Page generation time: 0.7470
