Forums >> Revit Building >> Technical Support >> Content hatch - rotate with component
Thu, Mar 31, 2011 at 10:05:01 PM | Content hatch - rotate with component
kbel4
I am using the "out of the box" OSB content.  I get a rotated hatch when I draw the osb horizontal vs vertical.  How can I get the hatch to rotate with the content.
I tried aligning the hatch, but it does not select with tab.
I have tried checking the box in the content for rotate with component, but it does nothing.  This is a family parameter.
HELP.
Fri, Apr 1, 2011 at 4:01:47 AM | Content hatch - rotate with component
4 Stars: 205 Votes
Is that hatch a "Drafting" or "Model" pattern?
Fri, Apr 1, 2011 at 9:36:48 AM | Content hatch - rotate with component
kbel4
It is a drafting hatch.  The family is the standard Revit OSB content that ships with the box.  See attached unchanged version.
Fri, Apr 1, 2011 at 12:26:45 PM | Content hatch - rotate with component
4 Stars: 205 Votes
That's why you can't select those lines with the TAB key, only with "Model" pattern you can do that.
Fri, Apr 1, 2011 at 2:52:43 PM | Content hatch - rotate with component
kbel4
So are you saying I need to change the hatch to model and it will work.  I'll try it.
Mon, Apr 11, 2011 at 10:22:41 PM | Content hatch - rotate with component
kbel4
Decided this was silly and wasting a lot of time.  Decided to just go with a poche so I did't have to mess with this.  You would expect out of the box content to work right when rotated.  Just one more thing to get frustrated at.
2d Line Based compnents - rotate hatch region for plan and section
Tue, Jan 31, 2012 at 9:28:27 AM
Component rotate
Tue, Feb 8, 2011 at 10:55:46 AM
Rotate model hatch on curved roof
Wed, Sep 4, 2013 at 10:44:57 AM
Cant rotate drafting style pattern?
Thu, Aug 18, 2011 at 11:08:52 AM
12
cant rotate fill patterns
Wed, Nov 11, 2015 at 8:05:43 AM
Page generation time: 0.5710
