Forums >> Revit Systems >> Technical Support >> Wall patterns?
Thu, Mar 31, 2011 at 2:10:41 PM | Wall patterns?
vhugomg
Is there a way to make a pattern, like a 60 x 60 crosshatch pattern on a wall that needs to be yellow on my sheet n views?
I mean, can we mix a filled color + patterns on walls or other revit elements.
I just cannot do it and became thin on new ideas to solve this with some simple and low poly method...
Thu, Mar 31, 2011 at 2:55:52 PM | Wall patterns?
mhans
3 Stars: 10 Votes
Is it just one wall? Override the property of the wall and click on surface pattern and apply your 60x60. You need to make a 60x60 crosshatch from Settings-fill pattern. If many, create a wall type and change it's property.
Motto: "No Post left behind"
Thu, Mar 31, 2011 at 3:01:46 PM | Wall patterns?
You can create a materail for this.... just add the pattern to it.  If you want the pattern in 3d views, it needs to be a 3D pattern ... better if it is anyway so that you can adjust it.  If you want it in renderings, then it needs an associated jpg material image.
Thu, Mar 31, 2011 at 4:17:20 PM | Wall patterns?
thetabest
thetabest Avatar
3 Stars: 2 Votes
View Filters make a great method too, without having to change the rendering properties of the object.  For example, fire rating, add the parameter if it isn't already there, populate it, then create a view filter for each of your different ratings.  These filters should apply to walls only (unless you know what you are doing, then you can be braver), should "look" at your fire rating, and should compare it to the value (i.e.- 1 hour fire smoke might be one which you use, and stored in the fire rating parameter should be 1 hour fire smoke).
Finally, you need to add the filters to the view, and then override the pattern to your desired pattern + color.  For example, in one project, we had our 1 hour corridor rating which was a black square, white square pattern on print, but in our plan/RCPs appeard as yellow squares/white squares... We had other ratings whith each appearing a different color, green, blue, orange, etc. so that we could tell the rating at a glance...
If my explanation wasn't clear enough, please search for view filters, everything you need to know will be there...
GL
Trent Best
Best Systems
the.tabest@gmail.com
Thu, Mar 31, 2011 at 4:38:02 PM | Wall patterns?
vhugomg
Mmm, But how do you do a yellow wall with a 60x60 model crosshatch pattern on a hidden line view?
I had a curtain wall with yellow panels already done, but I want to change it to a simple wall with this properties because I think it´s a better solution for my project, it's easier to modify and I prefer not to use curtains on this case...
Thanks for all your replies.
Thu, Mar 31, 2011 at 5:37:47 PM | Wall patterns?
thetabest
thetabest Avatar
3 Stars: 2 Votes
Once you have created the wall filter for each rating, add it to your filters (under visibility graphics overrides), then there are 4 override boxes, 2 for projection/surface (ignore these) and 2 for Cut.  Under the overrides button for Patterns (under the Cut section) if you click on this button, you can assign a pattern to the objects, AND you can assign the color also...
GL
Edited on: Thu, Mar 31, 2011 at 5:38:45 PM
Trent Best
Best Systems
Thu, Mar 31, 2011 at 5:40:38 PM | Wall patterns?
thetabest
thetabest Avatar
3 Stars: 2 Votes
Trying again, for some reason didn't show the image I captured to help you out...
Edited on: Thu, Mar 31, 2011 at 5:42:06 PM
Trent Best
Best Systems
Thu, Mar 31, 2011 at 5:58:07 PM | Wall patterns?
mcantwell
mcantwell Avatar
vhugomg
I don't think there is a way to have what you want.
Pattern and colour options in hidden line view mode
option 1
Set grid pattern (say vertical) and colour (green)
Output - green stripes on white wall
Option 2
Set pattern to solid fill and clolour to green
Output - green solid colour
Solid colour and pattern on wall are mutually exclusive in hidden line view. One or the other only.
Matt
Thu, Mar 31, 2011 at 6:06:56 PM | Wall patterns?
vhugomg
At least I confirmed what I believed from the beginning: It´s not possible to make a pattern with and a fill color on a wall at the same time.
I think it should.
Thanks a lot for your help!
Thu, Mar 31, 2011 at 6:10:14 PM | Wall patterns?
thetabest
thetabest Avatar
3 Stars: 2 Votes
LOL, now I'm confused, I see what you are saying mcantwell... I used custom patterns, which I made myself, so in order to get the 60x60 crosshatch, you might have to make a pattern which shades the squares...  As mcantwell pointed out, whatever is normally black, is what becomes whatever color you set it to.  Thus, if you want say white lines between the yellow tiles, then you have to make a pattern which shades each tile (currently, the patterns shade the grout, if you will).
Trent Best
Best Systems
Thu, Apr 14, 2011 at 12:11:27 PM | Wall patterns?
#11
dafrankn
the only way would be to apply a solid color to the surface and go in and draw the pattern with model lines. then you have to hide the model lines in views you dont want to have it show.
wall fill patterns for different wall types and phases
Sun, Apr 24, 2016 at 4:42:58 AM
Wall patterns
Wed, Jul 5, 2006 at 3:08:13 AM
WALL PATTERNS
Tue, Feb 4, 2014 at 3:33:47 PM
Where do model patterns go?
Thu, Sep 24, 2015 at 9:37:41 PM
How to Import Hatch Patterns
Thu, May 31, 2012 at 1:16:12 PM
Page generation time: 3.6255
