Forums >> Revit Structure >> Technical Support >> Adding slab spans to callout views
Thu, Mar 31, 2011 at 4:31:41 AM | Adding slab spans to callout views
ash86
Hi guys and gals,I'm using Revit 2010 and I have a building just now with a small area of foundations and slab which are lower than the rest. I originally started to use a plan region to show all of this on the same plan but as time has went by, and the more information we need to show, this has become very messy.What I have now done is create a detail callout view so that I can isolate this area at a better scale, but still show it on the same sheet as the rest of the building.So far so good.I have done the same process on the ground floor view also. This is where it's throwing me a curveball. I'm trying to apply a slab span arrow to the portion of slab at the lower level, but each time I try to do, so I get this message;'Can't create this kind of element in this view in the current mode.'I’ve double-checked all the view settings and can’t see anything. I’ve also had a quick scan online for posts relating to this but can’t seem to find anything.Any help would be much appreciated Jash86
Thu, Mar 31, 2011 at 3:01:10 PM | Adding slab spans to callout views
mhans
3 Stars: 10 Votes
Can you attach a screenshot? I'm not getting it. Did you try duplicate-dependent and crop region?
Motto: "No Post left behind"
Fri, Apr 1, 2011 at 3:10:52 AM | Adding slab spans to callout views
ash86
Sorry chaps, an amateur mistake here
I've just recreated the callout and have noticed my previous one was a 'detail' view rather than the 'structural plan' view.
Not sure why I get the issue in the detail callout but all seems normal when in the structural plan callout.
Crisis averted, but thanks for the reply anyway mhans
ash86
CALLOUT VIEWS . . .NOT SHOWING UP?
Wed, Aug 10, 2011 at 1:16:06 PM
adding radius edge to floor slab
Wed, Jul 21, 2010 at 7:47:29 AM
Detail Callout Bubbles and Dependent Views
Thu, Aug 12, 2010 at 6:51:10 AM
Building section callout visibility in intersecting views
Mon, Jun 16, 2008 at 12:40:58 PM
Slab Edge Profile... Except Up...
Wed, Nov 11, 2009 at 7:00:24 PM
Page generation time: 0.3074
