21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> Curtain wall question!
4 Posts No Rating |
This is probably a stupid question, but I haven't been able to find a solution.
I was wondering if its possible to make a curtain wall in the area that i market with yellow on the picture?
I have tried to split the wall, but i cant get the same shape.. Is it easier to make a window?
4 Posts No Rating |
I should probably have posted this in the newbie forum instead.. I'm sorry..
Draw your curtain wall on top of the existing wall, adjust the height parameters of the curtain wall to suit the max / min heights. 'Cut' Geometry of your red wall to join the curtain wall to it. Use 'Edit Profile' to trim to the correct shape. Voila.
You don't need to edit profile. Just check the embed checkbox on the curtainwall and it will embed itself. Do use edit profile on the Curtainwall if it is not a rectangle.
4 Posts No Rating |
As you see from this picture, I cant cut of the corners on the curtain wall.
I only get dotted lines and the wall goes outside the red one!!
How do i get this right??
4 Posts No Rating |
I got it now.. Thanks for the help!!
Look below.....
Curtain wall door frame |
Mon, Mar 2, 2015 at 11:37:33 AM
Curtain wall question |
Wed, Jul 29, 2009 at 2:39:13 AM
Revit 2013 Curtain Walls |
Thu, Jun 20, 2013 at 2:44:40 AM
Curtain Wall Issues_Edge Joint |
Fri, Jun 1, 2007 at 1:36:41 PM
Curtain wall in wall hole |
Tue, Sep 8, 2009 at 7:03:33 PM
