Forums >> Revit Building >> Technical Support >> Rendered Glass and Sky
Sun, Nov 13, 2005 at 8:32:19 PM | Rendered Glass and Sky
phillipm
An observation and a question....I've noticed in my own renderings and those in the gallery that glass does not seem to render the sky reflecting in glazing. Is there something I'm missing, or does Revit not cater for this??? Any ideas. Thanks PhillipM
Mon, Nov 14, 2005 at 1:58:05 AM | RE: Rendered Glass and Sky
eldados
eldados Avatar
4.5 Stars: 8 Votes
glass does reflect the clouds, just make sure that your map is set up properly with reflection... Revit Accurender is not the best, in fact it's a cut down version! but you can still produce nice (the term "nice" is used loosely) renders, but you need to play with it a lot! Smile
Integrator
KarelCAD
Mon, Nov 14, 2005 at 3:35:38 AM | RE: Rendered Glass and Sky
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You need to utilise a spherical or cylindrical background in order to have clouds etc reflected in the windows as well as having back face culling turned off.
Mon, Nov 14, 2005 at 5:35:53 PM | RE: Rendered Glass and Sky
eldados
eldados Avatar
4.5 Stars: 8 Votes
"You need to utilise a spherical or cylindrical background in order to have clouds etc " I did it without, it is not as good, but does reflect...
Integrator
KarelCAD
Tue, Nov 15, 2005 at 10:01:50 PM | RE: Rendered Glass and Sky
phillipm
I couldn't get it to work satisfactorily (I'm a perfectionist). I'm now playing with using an Internal rendering for an external view with Sun as the only light source. Much better rendering all round but the shadows are very dark (black). I've already posted this, but anyone know if the shadow colour can be over-ridden?
Mon, Jul 8, 2013 at 3:53:08 AM | Rendered Glass and Sky
bradclarke1991
ho do you turn off back face culling?
Revit 2012 Sky Reflections in Glazing
Mon, Jul 14, 2014 at 9:00:54 AM
RAC 2009 Sky Rendering Problem
Thu, Jul 10, 2008 at 7:37:36 AM
Rendering with no sky.
Sat, Mar 21, 2009 at 2:49:59 PM
11
Trouble with sky for rendering
Wed, Jul 21, 2010 at 9:10:26 AM
How to have glass facade with black framing after it is rendered?
Wed, Jan 12, 2011 at 7:00:07 AM
Page generation time: 0.5552
