18 Users Online (16 Members):
Forums >> Community >> Newbies >> no value in my tags
I've set up a schedule and a sheet with my schedule in it. It contains some trees in a test project. The schedule comes up with the tree info. but none of the tags have a value. They're just blank. I thought it might be my family of trees, but the RPC tree that I used is doing the same thing. Can anyone help?
The tag has to read the proper value in the element. What tag are you using? What parameter does it read? Is that parameter in the tree family? Is that parameter set?
I'm using a planting tag. I took the one from the imperial library and touched the appearance of it up, but didn't mess with the parameters. What parameter do these read? I've tried to add Mark, Type Mark, Keynote (but I don't think that's what I need). As far as the trees, I'm currently working on the plan views before I implement the 3D part, but like I said before, it didn't even read the Cherry Tree that came with the program. Thank you for your help and I hope this helps some.
The planting tag reads a type parameter called Type Mark and mine works fine.
tags tags tags |
Tue, Mar 20, 2012 at 12:10:23 PM
Tags linked in more than one view |
Fri, Feb 27, 2009 at 6:21:47 AM
ROOM TAGS |
Fri, Jul 29, 2011 at 8:25:58 AM
MISSING elevation tags |
Mon, Sep 17, 2018 at 10:55:17 AM
room tags |
Thu, Aug 13, 2009 at 3:54:34 PM
