Forums >> Revit Building >> Technical Support >> Cascading Curtain Wall
Tue, Mar 29, 2011 at 6:45:09 PM | Cascading Curtain Wall
bushman2
Hello all,
need some help in creating a cascading curtain wall, similar to the attached image,
anyone know how?
Adam
90288_1297362968-6i-norwegian-wood-6-709x1000.jpg90288_1297362956-6i-norwegian-wood-3-1000x732.jpg
Tue, Mar 29, 2011 at 8:10:19 PM | Cascading Curtain Wall
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
create a cw from scratch, make a reference line from the top constrain. There you can add an angle constrain. Create a extrusion from that , make sure it overhangs the bottom. Go to the exterior or interior view and overhang there too, you can add a parameter ther for that. Then replace the panels you need to overlap, and your done. Hope you understand it :S
Wed, Mar 30, 2011 at 8:39:51 AM | Cascading Curtain Wall
pchan
pchan Avatar
5 Stars: 5 Votes
You won't be able to achieve this with typical curtain wall (curtain panel) system even you make your own. since the curtain panel cann't follow the ridge slope.
I would say you can try to use curtain panel pattern panel with conceptual mass family to achieve this.
Wed, Mar 30, 2011 at 8:50:55 AM | Cascading Curtain Wall
You will not be able to do this with a CW or using a wall by face.  It appears that these glass panels are shingled as they go up.  I would probably model them as walls with end joins and room boundry turned off or use a special "wall" category family.  That might be better because it could contain those "spacers" that offset the glass as they are shingled.  The family could be type base sized.
Cascading Building Block
Sun, Aug 29, 2004 at 10:22:41 PM
Curtain Wall Panel to Curtain Wall Door
Mon, Jun 23, 2014 at 9:32:11 AM
Curtain wall not cutting through moulding
Thu, Oct 22, 2015 at 2:53:44 PM
Splitting a curtain wall to change the type of wall it is
Thu, Aug 6, 2009 at 12:46:42 AM
Can't Put Curtain Wall Inside Stacked Wall??????? Help Needed
Thu, Jan 24, 2013 at 8:06:06 PM
Page generation time: 0.9414
