Forums >> Revit Building >> Technical Support >> The quickest way to show houses in a site map?
Mon, Mar 28, 2011 at 1:59:03 PM | The quickest way to show houses in a site map?
Pepinho
Hi Guys,
I am currently working on a site plan for a piece of coursework, showing the view from the proposed building out onto the car park, fields and it does look fairly good but there are lots of houses in the distance and I would like to show this on revit. What would be the best was to show the row of houses?
As always, thank you very much for any help.
Mon, Mar 28, 2011 at 2:48:44 PM | The quickest way to show houses in a site map?
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
I see a lot of companies that will use an image from Google Earth otherwise they will use the massing tool generate some generic looking forms (recognizsable of course) and copy those around on the site.
A side note here, you would wise to place all those masses or what have you into a seperate Revit model and link that into your project to reduce the file size and maintain a good level of system performance.
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Mon, Mar 28, 2011 at 2:58:36 PM | The quickest way to show houses in a site map?
Pepinho
Thank you for the reply - Can I ask how you would use google earth like you said some companies use. How do you go about about?
Mon, Mar 28, 2011 at 5:29:27 PM | The quickest way to show houses in a site map?
brettgoodchild
4 Stars: 17 Votes
If you are on subscription, you can use the Globe Link for Revit 2011 plugin.
If not, Imaginit  has developed their own...formally called Avatech Utilities
http://imaginit.com/software-solutions/building-architecture/imaginit-utilities-for-revit-2011-named-user
                             ~ Abraham Lincoln
Tue, Mar 29, 2011 at 8:22:22 AM | The quickest way to show houses in a site map?
Bimman
Bimman Avatar
1 Stars: 2 Votes
we massing objects of generic shapes.
PWD
site map?
Thu, Oct 4, 2007 at 3:31:36 PM
3D model of a new site with 10 domestic houses on. Need method advice
Wed, Jun 22, 2011 at 12:25:27 PM
2d Location Map
Tue, Nov 8, 2005 at 4:58:49 PM
Best Software for Modular houses?
Thu, May 13, 2010 at 9:30:01 AM
Material image map problem
Mon, May 11, 2009 at 2:37:29 PM
Page generation time: 1.4534
