Forums >> Revit Structure >> Technical Support >> Recycled grids
Mon, Mar 28, 2011 at 7:54:24 AM | Recycled grids
albertiglesia
albertiglesia Avatar
hi,
we are doing a series of small sized structures and the project manager has decided to squeeze the number of drawings in as small as possible by combining the two different models (building 1 & building 2) into single file. the question is how can i make the grid of both buildings to use grid 1, 2, 3 ... (grid A, B, C...)? or simply make their grids the same (not the distance). is it possible to use the grid sequence more than once?
your help is very much appriciated
thanks in advance,
albertiglesia
"Pleasure in the job puts perfection in the work"
 - Aristotle
Mon, Mar 28, 2011 at 8:21:03 AM | Recycled grids
albertiglesia
i tried to link building 2 file to building 1 file to make all its (building 2) annotations and grids the same as it is in building 2 making building 1 have identical grids on 2 models but still the question remain, is there other way to do this? if i will bind the link, the grid of the inserted link will be automatically edited by revit, removing my desire to have identical grids on two totally different models or plan. please help me
thanks in advance
 - Aristotle
Grids at an Angle in Plan don't display in Elevation
Thu, Apr 26, 2012 at 2:44:38 PM
new user - copying grids to other levels
Mon, Dec 6, 2010 at 3:06:35 PM
multiple scope box for grids
Tue, Sep 1, 2015 at 8:35:46 AM
DIMENSIONing GRIDS - on plan view
Thu, May 26, 2011 at 1:33:19 PM
2D and 3D Grids
Wed, Oct 17, 2007 at 10:04:13 AM
Page generation time: 0.9754
