Forums >> Revit Building >> Technical Support >> wood braced walls
Fri, Nov 11, 2005 at 6:37:20 PM | wood braced walls
McGraw
Does anyone have a slick way to show wood shearwalls/braced wall panels in plan view? I think the best thing I’ve come up with so far is a framing family that I can draw like a beam and tag. I had to make a separate family for holdowns and tag separately. I also tried annotation symbol and detail component, which seems like it would be quicker, but each had issues. I can’t believe I am having to try and re-invent the wheel on this one. Would really appreciate your thoughts. Sam Post edited on 2005-11-11 18:37:37 Post edited on 2005-11-11 18:40:05 Post edited on 2005-11-11 18:40:24
Sun, Nov 13, 2005 at 6:01:52 PM | RE: wood braced walls
eldados
eldados Avatar
4.5 Stars: 8 Votes
do you need to show it in plan only? if so, I would use a detail componenet and put the annotation in it, though if you need to tag, creating a family is not a bad idea...
Integrator
KarelCAD
Tue, Nov 15, 2005 at 6:00:54 PM | RE: wood braced walls
McGraw
Yes, just plan view. I think my Braced Wall and Holdown families and corresponding Tag families are going to work well. Seems to be the most efficient. Thanks for the reply. Sam Post edited on 2005-11-15 19:15:56
Fri, Jun 16, 2006 at 11:18:09 AM | RE: wood braced walls
McGraw
Thank you AutoDesk for adding the line based detail component in v.9. Sam
Wood Siding
Fri, Nov 22, 2019 at 3:17:58 PM
11
Wood Framing Walls Extension Review
Thu, Sep 23, 2010 at 2:51:06 PM
wood framed walls
Sat, Sep 16, 2006 at 5:04:06 PM
Wood Framing Walls Extension; Locating and External framing
Fri, Jul 31, 2015 at 8:03:14 PM
Wood floor way too shiny.
Tue, Dec 14, 2010 at 7:32:39 AM
Page generation time: 2.3406
