Forums >> Community >> Newbies >> letting text dictate a numeric value
Wed, Mar 23, 2011 at 10:34:58 PM | letting text dictate a numeric value
JonathanCullinan
Hi there,
 i've seen this same question posted a fair bit however none of the answers have seemed to help me. admittadly i am new to Revit so please bare with me.
What im basically trying to do is a seemingly simple task relating to room occupancy scheduling. What I’d like to do is assign a numeric value (in this case the occupancy load per square metre) to a text field, furthermore allowing me to then use the numeric value represented by the text field  in a simple occupancy load calculation. So for example; say we let the category’ Board Room’ (text) represent a numeric value of ‘2’, any rooms  that are then categorised  to be a ‘Board Room’ will then have their occupancy load calculated according to the appropriate variable (in this case 2).
Cheers, Jonathan.C
Thu, Mar 24, 2011 at 7:43:20 AM | letting text dictate a numeric value
Text is text ... it is not a number so you can not use it mathmatically.  Revit also has no text formulas at this time.
Sun, Mar 27, 2011 at 7:42:32 PM | WWHub
JonathanCullinan
Quoting WWHub from 2011-03-24 07:43:20
So there is no way to do something basic like let x = 2?
Mon, Mar 28, 2011 at 7:23:36 AM | letting text dictate a numeric value
You can always use a parameter ...
Tue, Mar 29, 2011 at 7:07:20 PM | WWHub
JonathanCullinan
Quoting WWHub from 2011-03-28 07:23:36
That sounds promising, by using a parameter would that enable me to achieve the following?
(If so im still not quite sure how to set one up)
Room     (Parameter)     (Calculation using Parameter)
 Office        office     .......
parameter office = 2
Thanks in advanced WWHUB
Wed, Mar 30, 2011 at 7:11:19 AM | letting text dictate a numeric value
Your answer is in your HELP if you ever choose to use it.  Look up parameter.
Wed, Mar 30, 2011 at 6:17:12 PM | letting text dictate a numeric value
JonathanCullinan
Care to point me to the help article you are referring to? Because thats the first place i sought answers....
Specifying Numeric Parameters with Text
Mon, Oct 9, 2006 at 7:17:28 PM
how to -- define numeric parameters in Family Window
Wed, Sep 15, 2004 at 9:30:59 AM
Working out door location for schedule
Tue, Aug 3, 2010 at 10:13:13 AM
Calculated field on sheet to state whether "numeric" or "Alphabetic" no. used
Tue, Jul 10, 2012 at 7:07:05 AM
Revision Numbers
Wed, Jul 27, 2011 at 12:30:32 PM
Page generation time: 0.3901
