Forums >> Revit Building >> Technical Support >> Viewport Text
Wed, Mar 23, 2011 at 4:22:06 PM | Viewport Text
cglyon
How does one adjust the length of the viewport title wrapping in Revit 2011?
Wed, Mar 23, 2011 at 4:46:49 PM | Viewport Text
thetabest
thetabest Avatar
3 Stars: 2 Votes
One creates a new view title, if you create your family with this in mind, take the same label, but copies of it, making them different lengths, lets say short, medium, long.  Create the yes no parameters to go with, and set them to control the visibility of each of the different labels you made.  Load family into project, click on the viewport on a sheet, select type properties, then select edit, make a new title using the family you created, a short, medium and a long.  Now you can assign per your need.
 Revit doesn't allow much flexibility to be controlled from within a view title, as you can't propagate any of the data or controls to your family, so you have to create different viewport types for each different method of displaying a title.
 GL
Trent Best
Best Systems
the.tabest@gmail.com
Wed, Mar 23, 2011 at 4:53:51 PM | Viewport Text
cglyon
Thats what I thought, but I was hoping there was a better/ easier way. THANKS!
Wed, Mar 23, 2011 at 4:58:21 PM | Viewport Text
thetabest
thetabest Avatar
3 Stars: 2 Votes
Not that I'm aware of, albeit most of my research to this end was back in version 2009, but nothing has changed towards that end to cause me to think it is any different.  PLEASE somebody prove me wrong, in this case, I'd LOVE to be wrong, I hate not being able to control the length of a label, when it wraps, etc.  You should be able to allow/disallow the stretching of text of a family/nested family.
GL
Trent Best
Best Systems
Viewport Text
Wed, Mar 9, 2016 at 10:00:08 PM
Stretch/move text location in Viewport Title
Wed, Sep 12, 2018 at 4:06:35 PM
Draw Order of Viewport on a sheet
Wed, Dec 16, 2009 at 4:35:58 PM
viewport annotation box
Mon, Jun 2, 2014 at 8:49:40 AM
Is their a way to change the Viewport referencing?
Wed, Sep 21, 2016 at 3:16:25 PM
Page generation time: 2.2591
