Forums >> Revit Building >> Technical Support >> Cavity sliding door adjustment puzzle
Mon, Mar 21, 2011 at 5:18:29 AM | Cavity sliding door adjustment puzzle
Pele
Pele Avatar
Macca u gave me this door a couple of weeks ago, that is great thanks.
I have been using it but when I change its properties for a 920  it does not schedule as 920 it comesout as the cavity slider unit width at 1900. Hve you or anyone got an idea how to make this schedule at 920, which is what the builder will want to know when he orders the door.
I will be scoring goals soon, I'm in the back line at the moment!
Cheers Dermot
www.dmbd.net
Mon, Mar 21, 2011 at 9:22:34 AM | Cavity sliding door adjustment puzzle
pchan
pchan Avatar
5 Stars: 5 Votes
Pele,
The door is not done correctly in my opinion. in a typical door family, there are only a few parameters that can show up in a door schedule. (e.g. width, height, rough width, rough height, thickness) Anything other than that will not be schedulable unless you made it as a shared parameters.
in your case, "door width" is a user created pararmeter (and not a shared parameter either), therefore, it will not show on the door schedule.
3 options that i can come up with...
1. is to fix the family so that the "width" in your door is the actual width of the door.
2. made that "door width" = 920 as shared parameter so that it will reflect on the door schedule
(note that this will open a can of worm if you don't know how to deal with share parameter
3. from your project, create a project parameter for your door, made it as a text parameter for your "door width" and fake the value to whatever you want. (this will be my least favourite option)
My suggestion is to go with option 1 .
since this will be a better solution if you decide to use this family for any future projects.
HTH Philip
Mon, Mar 21, 2011 at 4:36:16 PM | Cavity sliding door adjustment puzzle
Pele
Pele Avatar
Thx pchan
I will have to do a bit of learning to be ble to do that fix, but maybe by then I will understand families more
Cheers Dermot
www.dmbd.net
Cavity Sliding Door
Mon, Mar 13, 2017 at 8:04:09 AM
No cavity sliding unit in Revit (Aus) ??
Mon, Oct 11, 2010 at 12:35:59 AM
Curtain wall sliding door
Fri, Jul 25, 2008 at 10:31:57 AM
HM Door/Window Setback Puzzle
Fri, Sep 28, 2012 at 10:42:11 AM
Cavity Wall - Cavity Not Filled
Mon, Jun 16, 2008 at 5:42:38 AM
Page generation time: 1.1946
