Forums >> Revit Building >> Technical Support >> Creating a wall with a sloped top/head
Fri, Mar 18, 2011 at 5:48:05 PM | Creating a wall with a sloped top/head
iamian33
iamian33 Avatar
Greetings.
This one has me stumped ... I need to model a condition at the sill of the window, where the wall/insulation is sloped down and away from the window sill.  (see the attached image).
Is it possible or should I simply do the angled top with a sweep or or reveal? Or should I simply ignore it and deal with the issue in my details ... I don't want to over model but I would like to represent this reasonably.
I am using RAC 2011.
Ian Shafer
Principal Consultant
True North S&F Consultants
Sun, Mar 27, 2011 at 11:58:51 AM | Creating a wall with a sloped top/head
In your window family, you could remove the window opening and add new void cuts to achieve this.  Window families do not allow another void with the opening cut but do allow multiple voids.
You could also create a void family that is wall hosted that just provides this cut.
If you only have a few of these, you could do an in place void family.
Mon, Mar 28, 2011 at 3:04:36 PM | Creating a wall with a sloped top/head
iamian33
iamian33 Avatar
thank you for this suggestion.  We will investigate ...
Ian Shafer
HELP! Curved Sloped wall with slanted top
Sat, Jul 26, 2008 at 9:16:29 PM
12
How to make the top of the wall not horizontal?
Sun, Jan 23, 2011 at 7:17:41 AM
Sloped top of stone wall with wall cap on top
Tue, Mar 29, 2005 at 5:25:07 PM
complex massing
Thu, Jun 1, 2006 at 10:27:53 AM
A Sloped Curve Wall
Thu, Aug 7, 2008 at 4:17:27 PM
Page generation time: 0.8852
