Forums >> Revit Building >> Technical Support >> Detail Components & Wall Sections
Fri, Mar 18, 2011 at 9:40:38 AM | Detail Components & Wall Sections
Trav31
Is there a way to insert a detail component into the structure of the wall?  I know you can add sweeps, reveals, etc,  but I wonder if you can add a detail coponent the same way, something that only shows in drafting/sheet sections?
Fri, Mar 18, 2011 at 10:10:32 AM | Detail Components & Wall Sections
No, there is no way to do this at tihis time.
Fri, Mar 18, 2011 at 10:35:04 AM | Detail Components & Wall Sections
pchan
pchan Avatar
5 Stars: 5 Votes
One of the ways you can embed detail component is to nested it inside the profile family, then you can use the profile family to be part of integrated sweep for your wall type.
maybe that can help you to achieve what you want
You can also set the visibility to control the detail component to be shown on certain level.
Detail Component Visiblity in Sections
Fri, Aug 14, 2009 at 3:35:28 PM
Detail components in multiple views.
Tue, Aug 18, 2009 at 2:46:35 PM
masking linework behind components
Wed, Apr 5, 2006 at 6:03:28 PM
PLEASE CREATE MORE DETAIL COMPONENTS
Wed, Apr 20, 2005 at 7:46:13 AM
Detail Components with Demo Objects
Tue, Dec 30, 2008 at 4:34:29 PM
Page generation time: 0.8261
