Forums >> Revit Building >> Technical Support >> IMPORTED CAD THEN LINKED REVIT FILE
Thu, Mar 17, 2011 at 6:09:46 PM | IMPORTED CAD THEN LINKED REVIT FILE
RainaMc
RainaMc Avatar
Hello all,
I am working in 2011.  I have a revit file that has an imported Cad file in it.  However when linked in to another revit file the imported cad will not show up.  I did not have a probelm with it in 2010 and converted this to 2011 and it is not working.  Any one have any pointers?
Thanks,
Raina Mc
Fri, Mar 18, 2011 at 9:51:03 AM | IMPORTED CAD THEN LINKED REVIT FILE
TKennedy
4 Stars: 8 Votes
Make sure the linked CAD file is set to attachment not overlay.
Fri, Mar 18, 2011 at 11:31:15 AM | IMPORTED CAD THEN LINKED REVIT FILE
RainaMc
RainaMc Avatar
Thank you however the cad file is just imported it is not linked.  Any other suggestions.  It worked in 2010 but now does not work in 2011.  Is there some other setting I am missing?
Fri, Mar 18, 2011 at 12:04:56 PM | IMPORTED CAD THEN LINKED REVIT FILE
If this CAD file was imported in a single view, then you will probably have to set in your view that this revit link is by view and you will have to pick the appropriate view.
revit freezing and not responding when cad file linked
Fri, Feb 6, 2015 at 11:24:56 AM
Constraining to linked CAD file
Thu, Apr 4, 2013 at 3:09:14 AM
Revit 2008 - Linked CAD file changes location
Mon, Nov 19, 2007 at 8:49:58 AM
Revit Project Managment of Linked and Imported files
Mon, Sep 12, 2016 at 11:39:14 AM
Problem exporting view with linked CAD file
Wed, Mar 18, 2009 at 3:46:34 PM
Page generation time: 1.8246
