Forums >> Community >> Newbies >> Progataing property lines to floors
Thu, Mar 17, 2011 at 5:49:17 PM | Progataing property lines to floors
ecdraceofpsdaes
Hello everyone,
How can I propagate the property lines in a projects to ther floors besides underground floors and first floor? I tried copying and pasting the lines aligned to levels. It doesn't give me the option of pasting it to selected views and the checkbox for property lines is checked under the visibility settings for the current view.
Will I have to underlay the first floor plan? I want to avoid this, is there any other way to display the proprty lines in all floors?
Fri, Mar 18, 2011 at 7:14:13 AM | Progataing property lines to floors
You are trying to do something that Revit doesn't think is normal.  What you can do is to underlay your site plan and add 2D linework tracing your property line.
You might also be able to use an underlay view of the site with everything turned off in that view except for the property lines.
Fri, Mar 18, 2011 at 4:25:43 PM | Progataing property lines to floors
ecdraceofpsdaes
Ok, I guess I'll do that. Although it seems a bit strange as to why Revit would not show property lines in other floors than just the site, cellar and frist floors. I am doing a 15 story building right now and it would be very helpful if I could see the property lines in order to model my curtain wall properly
Property Lines + True North Rotation
Thu, Apr 26, 2012 at 2:34:45 PM
Property Lines on Toposurface
Mon, Jul 9, 2007 at 10:22:49 AM
property lines hidden by topography
Tue, Mar 6, 2007 at 11:47:47 AM
Property Boundary lines
Tue, May 30, 2006 at 10:45:31 PM
Property Lines - Thickness
Tue, May 2, 2006 at 10:35:02 AM
Page generation time: 5.4230
