29 Users Online (27 Members):
Forums >> Revit Building >> Technical Support >> Sloped beams
5 Posts No Rating |
Anyone know how to slope a beam to follow the pitch of a roof, or a reference plane drawn on the roof? Apoligize for the basic question. Cheers
Is it a structure beam family? if so, you should be able to use the start/end level offset value to make the beam slope OR you can draw a ref plane that is parallel to the roof, name the ref. plane, then u go to select the beam and say edit workplane to the ref. plane that u have. HTH
5 Posts No Rating |
Hey thanks,
I did the latter and it worked out. Appreciate the help.
Exposed beams help? |
Mon, Dec 19, 2011 at 4:29:57 PM
Sloped Beam Connection |
Thu, Feb 21, 2013 at 11:13:15 AM
Joist sitting on Sloped beams |
Wed, May 28, 2008 at 8:09:37 PM
sloped ceilings and beam system help? |
Fri, Dec 9, 2011 at 3:59:55 PM
connecting steel beams |
Thu, Apr 8, 2010 at 9:33:24 AM
