Forums >> Revit Building >> Technical Support >> Locking model group to reference plane in a family
Thu, Mar 17, 2011 at 10:51:02 AM | Locking model group to reference plane in a family
MattWtpc
Is there any way to lock a model group to a reference plane in a family so it flexes with the rest of the family geometry? I have a furniture family that flexes in width and I want to apply some 2D model line geometry in plan view that will flex with the furniture. Is this possible?
Thanks!
Thu, Mar 17, 2011 at 11:18:38 AM | Locking model group to reference plane in a family
pchan
pchan Avatar
5 Stars: 5 Votes
I would recommend to put those "Group elements" as a nested family so it can be locked to a ref plane
Did you say 2D model line? Model line is 3D is visble on all the views. be careful of how you do with those
Thu, Mar 17, 2011 at 2:23:49 PM | Locking model group to reference plane in a family
thetabest
thetabest Avatar
3 Stars: 2 Votes
First off, be wary of using model lines they are computationally intensive, to see this in action create an empty project, move around in 3D, everything is fast, now array (but not keep as a group) some 10,000, or whatever the maximum number of objects is in the array command and navigate in 3D, you should see some decent slow down.
 Now, on to answer your question, to get a group to move around, it needs a reference line, or plan as part of the group.  Then you can dimension to this reference plane or line, and give that dimension a label, and so forth.  The key is that the reference plan/line needs to be part of the group.
Careful with your use of model groups.  Groups are VERY computationally intensive, as pchan suggested, I recommend you use a nested family also.  PLUS, you can put a label to a nested family, and thus make your family more flexible, by being able to control the annotation/model compnent which is shown.
GL
Trent Best
Best Systems
the.tabest@gmail.com
Fri, Mar 18, 2011 at 8:48:06 AM | Locking model group to reference plane in a family
MattWtpc
Thank you both! That really helped me figure it out. I got rid of the model lines and made a nested family instead. Much better...
locking group to reference plane
Thu, Jan 25, 2007 at 1:19:43 PM
Families - Locking complex geometry
Thu, Dec 4, 2014 at 10:48:22 AM
mpdel line group constrained to Plane
Wed, Oct 17, 2012 at 10:43:46 AM
Locking structural framing to reference planes
Mon, Nov 14, 2011 at 5:37:03 PM
Locking Detail Curve to Reference Plane for Paramterizing (RAC 2012)
Tue, Mar 20, 2012 at 12:17:36 PM
Page generation time: 1.0454
