Forums >> Revit Structure >> Technical Support >> toposurface data import/positioning
Thu, Mar 17, 2011 at 7:18:09 AM | toposurface data import/positioning
iangus
Hello Im currently working on cut and fill exercises. We have accurate lidar surveys carried out which consist of nothing but x,y,z data.The first thing done on a fresh project is bring in this data to create a topo surface - (to later cut out various building pads to obtain cut and fill volumes). When the survey data is imported (via "create from import" then "specify points file"Winking to create the topo I get a warning of" Imported Toposurface Points are located a large distance from the model and might not display properly. Points will be centered on the model instead."- This then means revit has simply repositioned what was a very basic set of data wherever it sees fit which is useless. How do I avoid getting this warning? I have tried moving the new/blank model in revit with "specify coordinates at a point" previous to carrying out the import making sure that this will be within the range of the topo surface data points and still the same message appears.
Thu, Mar 17, 2011 at 2:43:37 PM | toposurface data import/positioning
thetabest
thetabest Avatar
3 Stars: 2 Votes
You won't be able to do as you were trying.  Revit does this to keep things from being rediculously far from the orgin point.  Unfortunately, surveyer's sometimes use as the origin point, some known marker (they typically use the same one based upon preference).  For example, they might "know" a location which is 5 or more miles from your site, and will use this as the 0,0,0 point.  Accept revit's interpretation of your data, you are just creating a local origin point.
BUT, if you REALLY want it in the correct place, then perform this:  Create a CAD dwg, with a shape highlighting and allowing you to find the origin (I use a several circles, like a target), LINK this dwg into your project origin to origin.  Now you know where your origin is in the project.  Move the imported toposurface to where it should be (I recommend adding a point to your point file, 0,0,0.  Now a point will appear at the 0,0,0 location, and you can thus move this to your origin point.
GL
Trent Best
Best Systems
the.tabest@gmail.com
Mon, Mar 21, 2011 at 3:31:58 AM | toposurface data import/positioning
iangus
yes - i really want it in the correct position - and so i will give your cad linking method a try  - all seems to make sense to me thanks very much for your comments
Thu, Feb 16, 2012 at 2:11:34 PM | toposurface data import/positioning
manorburn
Did this work?
Thu, Feb 16, 2012 at 2:36:56 PM | toposurface data import/positioning
thetabest
thetabest Avatar
3 Stars: 2 Votes
Actually, there is a better method, if you are using 2012, open up a plan view, then click on the little lightbulb to reveal hidden components, there should be a 0,0,0 marker, looks like a triangle with an exclamation point (I'm pulling this from memory, so forgive me if it doesn't look exactly like I said).  I don't know and haven't bothered to find out if this was available in 2011, I found it in 2012 for sure though.
GL
Trent Best
Best Systems
Fri, Dec 21, 2012 at 6:45:24 AM | toposurface data import/positioning
ihakki
Have you tried editing the CSV file to add a point at 0,0,0?  When you import the file, the 0,0,0 point will appear at the triangle marker thetabest spoke of.  I recommend deleting that point so your surface isn't terribly skewed.  Whether you delete it or not, the rest of the imported points will remain in the correct location.
It worked for me. Hope it works for you as well!
Flat Toposurface
Thu, Aug 3, 2017 at 8:58:49 AM
Toposurface creation using numerical data.
Fri, Oct 20, 2006 at 5:41:25 AM
Create Toposurface
Wed, Apr 22, 2009 at 5:06:53 AM
Using Survey Data to create a toposurface
Mon, Oct 4, 2010 at 2:23:28 PM
Toposurface Issues
Wed, Mar 28, 2012 at 1:50:09 PM
Page generation time: 0.2147
