18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Parametric door doesn't work when inserted in project
Hi everyone, I made this complicated door family and it took me lots and lots of time (and help from other users of this forum!) but now when I insert it in some project it says I can't create an instance of it. THAT MEANS I CAN'T USE IT!!! I tried deleting parameter by parameter from the family until I had almost nothing left in it and inserting again in some project but I always get the same message and I couldn't find where the problem is. Can anyone help me with this? If I don't find the problem I'm gonna have to make it all over again from scratch and insert it in another project after every little thing I do... Any help is appreciated.
Looks like your exterior trim is causing the problem, I deleted it and loaded it to the project and it works fine so fix your exterior trim (tie it to the workplane or recreate it) and it should work fine HTH Philip
Thats awesome, thanks a lot, Philip! :-)
Family Editor: works... then doesn't! |
Fri, Sep 2, 2005 at 5:23:05 PM
Help,what's wrong with my door family |
Thu, Dec 30, 2010 at 8:06:56 AM
Fully Parametric door with 45 angle swing |
Wed, Mar 26, 2025 at 11:13:10 PM
Door Number Memory |
Wed, Feb 8, 2012 at 2:18:29 PM
'Door' Won't Load into Project |
Tue, Sep 28, 2010 at 7:11:37 PM
