Forums >> Revit Structure >> Technical Support >> Stair Problem 2 !!!
Wed, Mar 16, 2011 at 7:51:33 AM | Stair Problem 2 !!!
cundall
does any one know how to change the railing profile on the stairs to a RHS 250x150x5 as in the attachment
cheers
Edited on: Wed, Mar 16, 2011 at 7:54:27 AM
Edited on: Wed, Mar 16, 2011 at 7:55:32 AM
Wed, Mar 16, 2011 at 11:46:20 AM | Stair Problem 2 !!!
pchan
pchan Avatar
5 Stars: 5 Votes
Go to Create New family --> choose profile-rail and drawing the shape of the RHS 250x150x5 --> save it and use it inside the system railing.
Thu, Mar 17, 2011 at 6:25:40 AM | Stair Problem 2 !!!
cundall
ive made my rhs in the RAIL PROFILE FAMILY, and put it in my model now is there a way of adding a material with it ?
regards
Thu, Mar 17, 2011 at 6:37:36 AM | Stair Problem 2 !!!
cundall
can anyone tell me if im doing Right or WRONG with my attempt in the attachment ?
im trying to attach the profile i made to the underside of the stairs
Thu, Mar 17, 2011 at 6:38:43 AM | Stair Problem 2 !!!
cundall
here is my RHS Railing profile family
Thu, Mar 17, 2011 at 8:22:01 AM | Stair Problem 2 !!!
pchan
pchan Avatar
5 Stars: 5 Votes
cundall,
Any profile family in revit cannot have more than one loop, in your case, you have 2 loops in profile, therefore, revit will reject it or say can't load family.
you can add material at where the setting of the railing is.
Thu, Mar 17, 2011 at 8:38:17 AM | Stair Problem 2 !!!
cundall
so really its not one of revits better tools then ? im not an expert at revit as you can tell but i would of thought it wouldnt of been that hard to put an rhs beam to the underside of a spiral staircase.
when i load the profile in to my model, it doesnt show up. i understand what your saying about the loops so i deleted one
thank you for your help tho
Thu, Mar 17, 2011 at 8:52:52 AM | Stair Problem 2 !!!
pchan
pchan Avatar
5 Stars: 5 Votes
Do you intend to put the beam to the underside of the center of the stair? you can change the offset value from the railing and adjust it to the center of the stair.
For your information, stair is one of the items that people are complaining about, it doesn't always do what you want and there are limitations, but the workaround has been working for me all these times.
HTH
Thu, Mar 17, 2011 at 9:02:22 AM | Stair Problem 2 !!!
cundall
i want to put 2 RHS's to support each end of the stairs.
im just trying to show my clients what Revit can do and give them a more visual idea on what im trying to acheive.
i really wanted the RHS to show up as a proper steel section instead of a white box.
i would love to know if and how this can be done.
 cheers for your help pchan
Thu, Mar 17, 2011 at 9:27:34 AM | Stair Problem 2 !!!
pchan
pchan Avatar
5 Stars: 5 Votes
I tweak the profile a bit so it shows a "tube" shape profile
You can see attached
 in your case, depulicate the same profile from the railing setting and change the offset value to the opposit side of the stair, it should be close to what u want
Thu, Mar 17, 2011 at 9:51:04 AM | Stair Problem 2 !!!
#11
cundall
your a star, thanks alot pal
Problem witch stair visibility
Wed, Apr 9, 2014 at 7:08:58 AM
Monolithic stair PROBLEM
Sat, Feb 9, 2013 at 8:14:32 AM
CAST IN PLACE STAIR PROBLEM
Wed, Mar 5, 2014 at 4:17:43 AM
11
Stair problem
Fri, Dec 4, 2009 at 9:51:26 AM
Problem railing arc stair
Thu, Dec 4, 2008 at 5:40:47 AM
Page generation time: 1.5597
